- pulleys
- Volant air intake question??
- Coolant leak
- setting timing_TFI-IV-4.9L
- Heater core fix...?
- KYFord or jefflaws
- What the....???
- Accel Blue Air Filter???
- PCV Valve location, please.
- idle rough and lopes
- Code reader needed
- Anyone else with a noisy K&N?
- Installing oil pressure switch
- UPgrades for 89 with inline 6
- my truck hesitates
- Oil filter comparison
- Ram Air material??????
- OH NO - not another 02 ?
- ProCharger Superchargers
- colder plugs in 98' 4.6 to solve pinging..
- Performance Mods
- O2 Sensor-Hints to change
- location of a ...
- Ignition Problem
- Burned Mobil1 synth at 4K miles
- Plugs and check engine light
- Warm up problems
- higher octane?
- Difference between Motorcraft spark plugs?
- no power in drive (gear 3) - fine in 1&2
- Misfire Cylider #6 (P0306)
- sensors and maf?
- Regular Oil or Synthetic!!!!!!!!!!!
- AC Compressor Question, Possibly FIPK Related?
- When I first start up the truck........
- New factory horn replacements avail...
- Holy Smokes This VOLANT R O C K S !!!
- Idle problem Solved - New IAC Valve Installed
- Which oil?
- ok how many miles can i expect a 98 5.4 v8 to last before problems?
- Slight Hesitation
- Bigger oil filter
- Headder GAskets....
- Any truth to this?
- Won't Crank
- 4.6 trouble!!
- Anyone add oil pres gauge
- Everyone should post, something..
- 5.4L engine..
- Oil Questions
- 4.6-lightning motor????? questions within.
- '97 4.6 Oil Pressure or Gauge???
- desert driving problems.........
- HELP, Something Went Wrong
- Oil guage going haywire!
- Bye Bye K+N, hello Volant Cold Air!
- Green coolant life and Plugs on '01
- 1980 302 won't start... help!
- Let's talk about a 9-Qt. Oil Filter System
- '97 F150 hard to get out of Park....
- 5.0 97 ford 150--NO POWER
- Using Chevron Techron for pinging.
- alternative to nos?
- Nav or Cobra Engine?
- ford let me down
- Airaid FIPK and K&N FIPK
- Navi man, need your oil knowledge. Please.
- Can't feel any difference?? Fipk & Factory intakes.
- better ignition coils?
- Engine intermittantly ticks when warm
- 5.4 Manufacturing Changes
- 4.6L V-8 Performance...
- What is the air dam for?
- Engine Service Code 1537
- Speedometer change
- Serviceenginecode1537
- Spark plug installation question?
- Black smoke, stinky exhaust, what the hecks wrong!
- air bag light... I think?
- Losing Power Slowly - '94 302 ... Long One
- More EGR trouble
- The First Oil Change, When, When NOT to ?
- When To Replace O2 Sensors?
- PCV Hose for 5.4 fix?
- Got truck back
- Bad Fuel Pump
- Cobra R Water Pump?
- Fuel Economy!
- 4.6 4x4 fuel economy
- 4.6L bolt-ons only
- Pulleys
- Dreaded Check Engine Light
- pep boys water pumps?
- motor mounts bad?
- Exh.Tip for Nascar
- March Power Pullys
- Taylor wires
- Neo Oil vs. Amsoil?
- truck wont idle
- engine specs help
- Any get an aftermarket warranty???
- plug wet...HELP!!!
- New 5.4l w/oil smoke?
- Cylinder head Temperature Sensor
- Engine problems... everyone please read
- motor
- Engines
- Help! 5.4 taking a dump
- check engine light EGR valve help
- Rough Idle, Fluctuating RPM at Idle
- Remote Oil Filter is in...THIS, is what a kit should look like!!
- 97 Lariat "Door Ajar" Lights up on...
- Opps! Forgot to gap my plugs!
- Help, 4.6L Uneven acceleration
- 5.4 in F150 vs. F250SD
- Shaving the heads on a 5.4???
- 5.4 swap, (oil leak)
- HELP...Fuel tank tube
- Squeeking belt noise at startup? Any ideas?
- hopping up a 300 6
- Check it out 3 Valves
- Engine stalling - Gremlins in the Engine
- Help! Miss fire #2 cylinder.
- My horn lost it's 'low" AGAIN!!!
- General ?'s about the Throttle body
- Rough Idle/ lugging
- Improved 2003 5.4l ?
- heater core???
- New HID Lights...WOW
- Truck won't start after washing engine
- basic repairs
- Engine Woes!!
- Upgrade Intake
- Jiffy Lube
- K&N airbox MOD
- Fuel pump shut off switch
- fan clutch
- truck stalls & slow to start........
- accelerator sticking to the floor
- Old truck needs some more power!
- burnt gas fumes
- Can someone run this Carfax? PLEASE?
- How does this sound???
- Questions about FIPK
- Built a 460....
- Why are Engine Sizes Posted in Liters?
- 4.6L misfire problems and remanufactured replacement engine
- fuel filter
- My 5.4l 0-60 tiimes...
- Crate engine
- Is It Worth It?
- Oil pressure
- products
- fuel filter
- Blown Plugs, damaged cylinder head
- Changed Wifes Oil
- Anyone in Kansas w/ OBD II scanner??
- Losing Power?
- When Can We Expect...
- increasing h.p
- Spark Plug Curiosity
- Mobil 1 5W20
- Low idle
- Mustang 4.6L in 98 F-150 Possible??
- power steering whine
- Engine Ping
- nascar engines
- Alternator Upgrade
- Spark Knock, Pinging in 4.6L
- Synthetic oil
- MotorCraft Wires
- Door cracks/ Door rust TSB's
- Throttle Postion sensor, mass air sensor??
- Superchrger Add-On?????
- 4.6 ignition system upgrades?
- Fuel Injector Cleaning Kit
- Problem! Throttle Shakey, Loss of Power!
- 2001L Ran Out of oil
- How do you check your fule mileage
- Coils and stuff
- Cold Start Noise
- Problem starting? help!
- Installing Cruise Control
- code 171 & 174
- Recommend a good OBD II scanner?
- No!
- Recalibrate Computer??
- A.T. MotorSports elec. supercharger
- oil indicator jumping around
- F150 Dies After starting
- Delta Pressure Sensor
- SuperChip Information!
- superchip
- which Oxygen sensor is which??
- 2002 5.4L info...
- 1997 f150 rough idle
- Help
- leak under engine
- Crappy Mpg So Far
- Splitfire review
- Check engine
- OBD II help...
- Which gauges are dummy gauges?
- 351 to 400 camshaft swap
- Spark Plug Wires ????
- 88 f 150 motor change 5.0 to 5.0 ho
- Trip Odometer diagnostic mode?
- Truck Shut off at Light
- Paging InfernalCombustion where are you!
- Engine downshifts rough
- Off topic, Flowmaster question...need louder!
- throttle body elbow
- K&N question....
- Is it worth paying the ford guys to...
- motor swap
- Coil, plugs and wires changed, runs worse! help
- CleaNed fiLteR, sounD is aWesOme.
- MSD ignition boxes
- OBD II scanning tool?
- How much boost?
- Fuel M.P.G. ?
- Engines, who sells them?
- A/C compressor always on?
- My BEST mileage!
- #7 cyl misfire 5.4L part 2 help quick
- what size injectors on 5.4?
- Removing coil pack wires
- New Truck Towing. Supercrew
- putting a 351w into a late model f150
- air intake kits
- Wipers
- Engine Noise?
- Service Engine Soon
- Parts for V6 F150s
- Diesel Engine problem
- Possible solution to freeing up HP.....
- Thinkin About an Oil Cooler??? Look here first...Oil temp gauge installed
- lightning crate motor! will it work in my 97 f150-4.6L ?
- Velocity Tube / intake hoses?
- Mind is playing tricks on me!
- Plug Wire popping off
- spark plug question
- heat kills hp
- Engine Shudder...
- Idle Air Control Valve
- anyway to diconnect rev limiter on v10 ?
- oil pressure gauge F150 vs. Mustang 302 computer
- Help!, big problem with my spark plugs
- AC Compressor Noise
