CE light Emission control leak?
Old Feb 14, 2006 | 10:17 PM
Thebikeguy1000's Avatar
Hey
I just changed motors in my 98 4.6 f150 and it was running good and strong for about 50 miles then i got a check engine light and i checked the code it said that i have a large emission control leak.
Any ideas would be greatly appreciated
Old Feb 14, 2006 | 10:23 PM
Quintin's Avatar
Check your gas cap.
Old Feb 15, 2006 | 07:46 AM
projectSHO89's Avatar
Also make sure you hooked up all the vacuum lines that go to the canister purge valve and from the valve to the fuel tank and that no lines were damaged or are leaking.
The purge valve is located on the firewall near the brake booster. Look for the green cap.
Steve
Old Feb 15, 2006 | 07:56 AM
LilBlackCoupe's Avatar
Originally Posted by Quintin
Check your gas cap.
gas caps are usually small evap leak codes.
recheck all your vacuum connections
