Need Help With Code
There are two valves in the back of the intak called 'Intake Runner Control Valves'. Do a search for these. I don't know a lot about them, but I do know that they can get stuck in one position or the other. Or hopefully you just have a broken wire somewhere in the circuit. I'm sure Quitin or Bluegrass will be along shortly and can tell you more.
Clear something up.
The code is for a V6 engine. ( intake manifold control circuit malfunction bank B)
What engine do you have? Is 4.6 an error and should be 4.2?
The trans flash is most likely a second problem and needs a higher level scanner to get the trans code.
