injectors
Old Feb 20, 2006 | 03:25 PM
1993F150's Avatar
injectors
Does anyone know if there is a way to check the injectors on a 1993 F150 w/a 5.0. I am still having a problem with spark knock and was wondering if my injectors are going bad. It has 172,000 miles on her and I have tried the sea foam, lucas products, changed several parts and still spark knocking.
The other problem that I am having is when you start it after it has set for awhile there is a slight vibration that comes and goes until it comes down off the fast idle. Any thoughts? Thanks
Old Feb 20, 2006 | 07:57 PM
Unlawful's Avatar
Registered User
change the EGR valve
Old Feb 20, 2006 | 09:09 PM
1993F150's Avatar
the egr valve seams to be working.
Old Feb 20, 2006 | 10:08 PM
metallion's Avatar
try putting a new timing chain and gear set on it. The chain is bound to be stretched out quite a bit by now with the mileage you have. This is the only way to be sure you have correct cam and ignition timing. Good luck!
