View Full Version : Engine
  1. Detonation
  2. 2004 Ford Speedo Question
  3. Intake question
  4. Injectors not working....???
  5. WOT Problem! Please READ!!
  6. How much oil PSI
  7. Abs ? ? ?
  8. Need new 4.6L F150 Enging
  9. Gear Ratios.
  10. engine swap
  11. Infrequent Miss Only in Overdrive under Load
  12. 97 5.4 oil pan removal
  13. Block Heater ?
  14. Hard Start/Stall/Rough Idle update
  15. spark plug gap
  16. O2 Sensor Bank1 Sensor1
  17. add hp??
  18. Heads
  19. Engine Noise
  20. EGR and roaring
  21. Missfire when almost hot
  22. supercharger question??
  23. HISSING SOUND WHEN TURN OFF ENGINE WITH A/C ON 2005 f-150 Screw
  24. knocking or clicking at any speed
  25. replace rod bearings ?
  26. Cam Questions
  27. Hunting misfire, need a little AutoTap help.
  28. service engine light on
  29. New Heads!!
  30. Question about 4.2L V6?
  31. Truck won't stay running. Any quick replies?
  32. ac on hit the gas and it only blows from the defrosters
  33. 05 FX4 Supercrew issue
  34. Steering Pump
  35. 5.4 set sos w/ethanol
  36. Oil Change Experience
  37. pcv value
  38. Who is in the 200,000 mile club?
  39. One fuel tank pumps into another.
  40. Water leaking/horrible idle
  41. getting a smell of gasoline after i park my car
  42. MPG. Tailgate up or down?
  43. Pinging or Air Intake Problem?
  44. Pinging or Air Intake Problem?
  45. Tech question/California Calibration?
  46. Engine codes
  47. Replacement Radiator
  48. 01 5.4 missfiring
  49. Cams for I-6
  50. Dull, Rythmic Thud
  51. need some tips for these plugs
  52. Are all modular motors this way?
  53. Few questions about misfires.
  54. Pinging / rough idle
  55. HELP!! Runs great at start, then runs rough
  56. aftermarket 5.4 triton heads with more threads ??
  57. Won't start
  58. O2 Oxygen Sensor
  59. Engine dies when I put it in gear
  60. Alternator is warm
  61. Tachometer option for 04-06 F150?
  62. 1992 4.9L Oil Leak???
  63. Whining noise in engine?
  64. First posting...weird sound from gas cap
  65. MPG drop and knocking after plugs/wires ???
  66. 97 Mercury Sable tune up
  67. Engine missfire after changing plugs.
  68. engine cuting out at 65
  69. pilot bushing removal?
  70. Self Tune-up. Hard?
  71. optima
  72. 2000 F-150XLT V8 4.6L Problems
  73. Intake Manifold question
  74. Knocking (slight)
  75. exhaust manifold "RED" hot on 300 I-6
  76. Throttle plate position
  77. Low oil, did I damage engine? 2004 5.4 Titan
  78. Truck won't start
  79. Vacuum leaks
  80. Replace 4.2 V6 with a 4.6 V8 Suggestions?
  81. new heads on a 2000 5.4
  82. bypassing the a/c compressor
  83. Bad engine miss,OD light flashing
  84. New motor opinions
  85. air rushing sound at start
  86. Temp. guage/overheat problem
  87. Diesel Engine's Life?
  88. Recent Mileage suprise
  89. testing
  90. still wants to stall
  91. Do Timeserts ever fail?
  92. About camshafts
  93. Which ECU do I use?
  94. Whistling 5.4
  95. 2005 F150 Trouble Starting
  96. 100000 Using 5w20 Mc ?
  97. f150 fuel pump problem
  98. Problem after running 15 Minutes
  99. R&R Oil Pan??
  100. Squeal after shifting
  101. No idle after getting muddy
  102. Starter?
  103. Misfire code P0303
  104. To big-sert or not to big-sert...
  105. 88 f150 sometimes starts/sometimes doesn't
  106. 98 Expedition Starts then stops
  107. Cross Threaded Spark Plug
  108. MORE POWER..... less gas
  109. erratic idle
  110. ??Sometimes takes a couple Cranks to start
  111. Howdy, first post....new f150 questions
  112. performance ?s
  113. Check engine light and no speedometer
  114. 330 V8 heating / overheating
  115. preping for mr. winter
  116. I have an Oil Leak
  117. squeeking ford.
  118. EGR tube
  119. Ignition Upgrade!!
  120. Electric Fan installed finally!!
  121. Finding a new or rebuilt 4.6
  122. Idles well at startup, but dies when stopping or turning
  123. 97 4.6 antifreeze leak
  124. fuel filter
  125. inertia switch
  126. Oil Priming Pre Starting
  127. routine maintenance on used truck
  128. Ignition Booster?
  129. Removing CNG cell on 2000 5.4L...
  130. antifreeze leak/heater core?
  131. 4.6 tryin' to get some respect
  132. 99 4.6 misses in high gear
  133. installing engine heat sensor harness
  134. Engine Won't Start after Oil Change
  135. Rev Limiter? Governor?
  136. 4.6 rebuild My Advice Don't Do It. Buy New
  137. fuel injectors
  138. need anwser on power steering fluid
  139. F-150 sputtering
  140. Blinking "Serve Engine Soon"
  141. check engine light
  142. I Kknow a 6.0l wont fit but what about a cummins 5.9l?
  143. Knocking noise 2004 5.4L Supercrew
  144. Power Steering Losing Fluid and Engine Coolant Problem
  145. RPM's bouncing???
  146. 03 Expy MAF, what injector?
  147. Fuel Tank Sending Units
  148. Question about K&N FIPK
  149. Non Plat. plugs installed
  150. '97 Oil Pan removal
  151. Which oil to use?
  152. replacing fuel filters
  153. IAC sensor
  154. 1998 5.4L looking for mods
  155. 2000 4.2 6 cyl maint
  156. 4.2 Valve Replacement
  157. gas tank change complete
  158. cold air intakes
  159. Triton Motor Statrter removal Made Easy
  160. No pointer on motor
  161. o2 sensor hard to unplug
  162. Cleaned MAF, IAC, TB & EGR, Still idles rough...
  163. interesting article (4.4l diesel)
  164. 5.8 Liter Temperature question
  165. Hard Start-shop answer..is it right?
  166. ford f150 making a noise
  167. Bosch Spark Plugs?...
  168. Engine Whining/Winding on acceleration
  169. Rattle noise
  170. Need performance advice
  171. 4.6-5.4 Skip Fixed!!!
  172. Ported head results?
  173. 7700?
  174. "knocking" sound; 05 5.4 lariat
  175. Engine Swap: 5.8L to 5.4L?
  176. Is 5.4 still the king
  177. Making the switch?
  178. Camshaft Position Sensor... What is its' purpose..
  179. Triton
  180. Truck starts, idle, RPMs drop to 0, and eventually stalls
  181. 4.6 rebuild My Advice Don't Do It.
  182. Didn't pass inspection
  183. Think I have a COP going bad
  184. Fuel Pump Won't Prime All the Time
  185. What Kind Of Oil?
  186. P0325 - knock sensor
  187. Bodykits
  188. quieston for Jmc
  189. 1988 4.9L I6 Injector Blower
  190. Engine stutters at steady speed
  191. injector info
  192. starter pinion and flexplate not meshing properly
  193. Helpful or Hoax?
  194. new owner/ member
  195. po307 after tune up
  196. optima battery upgrade
  197. 200 miles per gallon plus
  198. Air and Heat
  199. oil pressure
  200. Timing Belt, chain, or whatever...
  201. Differential torque specs?
  202. double intake
  203. 5.0 Oil Pressure Problem
  204. New member/owner of 2000 F150 7700
  205. Motorcraft Oil Availability
  206. cng 5.4's
  207. Cruise Control Fire
  208. Check Engine Light
  209. '04 F150 rattling @ start up
  210. Where can I buy repair book..
  211. 5.4 L shakes at 120 to 1900 rpm
  212. Need more power out of 4.6
  213. '93 F-150 5.0L fuel filter
  214. Cleaning EGR ports plug
  215. anyone know what code
  216. 03 Cobra motor swap??
  217. Iac
  218. 1997 f150 check engine light (error code) Long!
  219. Good engine?
  220. Troubleshooting electrical issue
  221. Vapor lock??? 86 F150
  222. Seafoam....Did I do it right?
  223. removing 5.4 from a '99 f150
  224. Ahhhh--the Head Gasket Once Again, Maybe
  225. Stalling after tune up
  226. trouble starting... some repairs still a problem
  227. Pinging
  228. New Fuel Pump
  229. Flat Rate info required
  230. 98 F150 still misfiring
  231. Well it happen again won't start
  232. Quick Question
  233. I think i was scammed on Ebay
  234. Disconnecting CC Switch.
  235. 351 Windsor.
  236. Repower V6 to V8?
  237. Engine smoke
  238. 99 4.2L F-150 Sputters upon acceleration
  239. almost stalling at stop sign
  240. 2005 F150 5.4 engine info/help needed
  241. When to replace hoses and which one to replace?
  242. EGR valve frozen bolt 1998 4.6L
  243. f 150 fuel pump
  244. 96 Throttle body leaking
  245. Cruise Control switch for F-250
  246. Weird acceleration/deceleration
  247. 97 F-150 4.6L Spark Plugs
  248. Intake experiment
  249. fuel leak help
  250. 100000 Maintenance 2000 expy 5.4?
