Truck is slow, real slow
Truck is slow, slow to built rev (video)
Since i've put my 35'' on the truck, the motor have a hard time pulling past 4K rpm. It make alot of noise, but doesn't pull ''hard'' and i have no check engine. Fully service 1 month ago and IMRC (intake manifold runner control) was replace 2 or 3 month ago.
Is that a normal ''problem'' from having bigger tire?
Or my truck have a problem?
2005 F150 FX4 with the 5.4L V8, stock gears, so 3.73
Edit: I have a magnaflow catback, K&N intake and Edge tuner.
I took a quick vid tonight, first gear only.
And my speedo was tune with a GPS.
It's just doesn't built rpm past 4k.
your truck has an electronic throttle and they have had problems. that could be your power issue. is your truck shifting under 4k at wot or is it not shifting at all unless you let off the throttle? but i would also think about slingshots post.
I guess it's just the big tires. It look good, but it's simply to slow
Atleast i have my GSX-R 1000 for speed
