No High-end HP after plug change
I recently had my plugs changed in my truck to Autolite HT15's. Overall the truck does a LOT better on mileage. I am taking 4mpg better. As I am getting about 16mpg now.
The bad part is, my truck falls on its face literally when I hit the higher RPM range. If I tried to kick it down and pass someone, I would have an easier time on a bicycle. This thing is a turd when this happens. I feel no bucking, no surging, no oddball feels. The engine RPMs just go up and I go no where.
Even with my Edge installed and on LvL3 with 93 octance, it falls flat. Stock does the same thing.
Only mods are a K&N drop in filter.
Do I need to take it back to the garage and have them troubleshoot? Or are there some easy things I can check here first.
it could be an issue with the electronic throttle. alot of these trucks are having this issue. some people on here say there are updates for these. my dad has an 06 f350 with 5.4 and torqueshift 5 speed auto. he had this issue everytime we make long trips pulling a trailer. i asked the dealer when i was getting my cruise control recall fixed if there were updates for this they said no, well we dropped his truck off later that day. when we picked his truck up about a week later he couldnt put his superchip back in because the dealer put an update in it and superchips had to rewrite the whole program just for this. we havent taken any trips with a trailer for a while so we dont know if its fixed yet. i'd check for these updates.
Could the plug gap be incorrect?
I asked what they gapped the plugs at and they told me .45
I will give it another week and contact them. Could be some bad gas.
ON a side note, could my cats be clogged?
I have an Edge so I am monitoring engine and cylinder head temperature. If I am running lean, how much of a difference in temperature am I looking at.
I have had auto lite dual platinums in my truck for 5000 miles with no problems except for a engine knock.
I done some digging around today and found an error code in my Edge.
P2006 Intake Manifold Runner Control (IMRC) Stuck Closed (Bank 1)
From what I have read is that once you get above 3500 RPMs, you will lose about all your HP/Torque. I don't have my Haynes manual on me for the fix, but I am going to have to drop this thing off at the shop again and have them fix it or repair it myself.
It keeps coming back even after clearing the code. But no CEL is on. ??????
