battery wires
Old Jul 9, 2008 | 01:32 AM
king ranch's Avatar
battery wires
wasnt getting answers in my other thread so i figured some of you guys would know in here since its related to the engine
i am trying to do the big 3 upgrade on the power and ground wires so my voltage doesnt go so low well i have a 2001 5.4l and the stock terminals that are on the pos wire that connects to the battery i cut off and there isnt much wire to connect back to my new terminals i bought
so i was wondering the wire that runs off the pos battery that runs under the engine to the back of the truck wat does that run and how can i make that wire longer so its not so tight on the terminal and ready to slip off
or can i not worry bout connecting that wire since the other pos wire goes to the relay or w/e it is by the firewall
Old Jul 9, 2008 | 02:55 AM
king ranch's Avatar
anyone
Old Jul 9, 2008 | 03:07 AM
jbrew's Avatar
Well it ends up at the starter solenoid down below , right below the passenger side exhaust manifold -
EDIT
[img]
[img]
Heres a new one and a new starter -
[img]
[img]
Old Jul 9, 2008 | 03:16 AM
jbrew's Avatar
Illustration -
EDIT
Old Jul 9, 2008 | 03:45 AM
king ranch's Avatar
ok is there any extra wire i can pull to the battery so its easier to connect and some slack in the wire or do i need to run all new wire from the starter to the batt or can i somehow connect more wire to exisitng wire
Old Jul 9, 2008 | 11:34 AM
MITCHYKINS's Avatar
change the cable will save lots of problems there not that bad
you may even be able to get a good used assy from a auto recycler
mitch
Old Jul 9, 2008 | 01:59 PM
king ranch's Avatar
ok so that is mounted on the firewall i wasnt talking bout that i was talking bout the pos and neg wire that runs under the engine whats the point of that wire and how can i make it longer
Old Jul 9, 2008 | 02:41 PM
tech-doc's Avatar
Looks like you screwed it up!
What was the problem to begin with?
If it aint broke, DON'T FIX IT!
Old Jul 9, 2008 | 02:43 PM
tech-doc's Avatar
Abdee, Abdee, Abdee, THAT'S ALL FOLKS!
Old Jul 9, 2008 | 05:04 PM
king ranch's Avatar
i was putting on aftermarket battery terminals to do the big 3 and connect my power wire for my amps
Old Jul 9, 2008 | 05:27 PM
tech-doc's Avatar
Well, sorry to hear that you cut the wire too short.
I have a 1000 watt kicker under the seat, and, voltage (was an initial worry with a 10 year old tryck) hasn't dropped at all, with stock terminal connectors. Shew, I couldn't imagine what would happen if there was more kaboom in that truck. I would be more deaf than I am now. LOL
And, I am having a blonde moment, but, could you explain the "big 3"? (for us slow folk please)
Old Jul 10, 2008 | 12:31 AM
king ranch's Avatar
big 3 you upgrade the pos alt to batt connection or run all new wire your self and leave stock wiring
then you run a new wire for your batt to chasis and the 3rd part is your chasis to your engine
you do the wiring it big wire as possible i am using 1/0 its to help voltage drops
this will explain better
http://www.caraudio.com/forum/showthread.php?t=152355
jbrew's Avatar
The Big 3 = Ford, GM and the other one.
That's all that means to me.. Well, for now.
Old Jul 10, 2008 | 07:41 AM
tech-doc's Avatar
You are aware that all of them grounds are already on your truck, right?
If you are worried about keeping your voltage at a norm, and, keeping the amp(s) rockin, you need a capacitor. Much easier than screwing up your battery cables and such.
Check it out:
http://www.crutchfield.com/App/Produ...sunami&tp=2614
Old Jul 10, 2008 | 12:43 PM
king ranch's Avatar
a capacitor does nothing in most apps check out the car audio forum and you will see upgrading the stock wires will help voltage since stock is like 8 guage or so and doesnt allow alot of current through
