Help with oil pressure
When cold startup everything is fine, after approx. 15 min. of driving the oil pressure indication will drop when I apply brakes to stop and the engine will then idle rough . I then place the truck in neutral and the pressure goes back up to normal. After 15 more minutes of driving it will not matter that I put it in neutral, but I have to idle the truck higher to keep pressure up. This motor has approx. 15,000 miles on it, the original motor was replaced a year ago.
Any suggestions at what to look at,check or replace before taking it to a shop.
Steve
Steve
If you are going by the dash gauge, don't. Get a mechanical gauge on it or you're guessing at best. I chased an issue like this with a 74 FE and the oil pressure would drop as did the idle...which it's suppose to do. Turned out I had a crack in the intake manifold between the heat for the carb and the intake runner. As I always said, I wished I could find a girlfriend like that- blow and suck at the same time. I doubt the oil pressure is the issue but an idle issue. I'd be looking at the EGR and other sources of excess air.
