my battery light goes crazy at 4k rpm
i have a 2000 f150 ext cab 5.4 an everytime i hit 4 or 5 thousanf rpms my battery light either turns on or flashes erratically.....why does it do this ......also i recently found out my truck is not running up to par with a 0-60 in 11 instead of the usual 8 or so......it has 70k miles on it and has ENVER had a problem with it...never been in the shop and i wouldnt be able to tell you if the service light worked because ive never seen it on and if that was related to my battery light flashing....I NEED HELP!
on
Knocking on 95K right now...I still have the factory belt on it....I know, I know, I'm on borrowed time....I just need to get a breaker bar...I have a new belt in the back seat.
Alternator still charging at 14.2-14.4 volts (HAM radios make good volt meters! when they have their display up!)
