Loss Of Power?
Old Jul 19, 2008 | 12:54 PM
Pappy68's Avatar
Loss Of Power?
I Have An 03 F150 supercrew lariat with a 5.4 liter and the son of a bitch will not brake torque anymore or even whip side ways it used to but after i change the plugs and cops it wont really seem to do it any more. i was just wondering if anyone new what i could do? thanks
Old Jul 19, 2008 | 03:59 PM
torkum's Avatar
Start with cleaning the MAF. Do a search for more info about the "Mass Air Flow" meter.
Old Jul 20, 2008 | 02:06 PM
Pappy68's Avatar
yeah i cleaned that a little while ago with alcohol and a Q-tip it was pretty dirty though
Old Jul 20, 2008 | 02:27 PM
Matts ford's Avatar
the modular engines are picky about there spark plugs. what plugs did you use? you need to use factory motorcraft plugs because they are built to factory specs. and they make a very big difference. there have been many cases like this where motorcraft plugs have fixed the problem.
Old Jul 21, 2008 | 05:43 PM
Pappy68's Avatar
I used the Bosch platnum plugs that they said dont require regaping
Old Jul 21, 2008 | 08:35 PM
Bartak1's Avatar
Did it happen right after you changed the plugs and COPs?
if so, and your 100 percent certian everything is right....
....Take them out and leave them out. These engines HATE Bosch plugs...
Old Jul 22, 2008 | 06:29 PM
Pappy68's Avatar
Yeah i went over it a couple of times i am pretty sure its right. well thats good to know i wish i knew that before. so how about motorcraft?, or autolight?, Also do u think that performance cops would make a difference?
Old Jul 22, 2008 | 08:28 PM
torkum's Avatar
Get the Bosches out. This is a picture from a '02 5.4 that was losing power after a week. Notice the electrodes are gone!
Old Jul 22, 2008 | 08:35 PM
jbrew's Avatar
And hurry
No No - Not Autolites either, there not spec. MOTORCRAFT's ONLY.
Old Jul 22, 2008 | 08:48 PM
scottbigred's Avatar
and when you clean your maf. dont touch it with anything. just spray it with electrical contact cleaner.
Old Jul 22, 2008 | 11:53 PM
Bartak1's Avatar
When it comes to ignition components, its hard to beat the factory stuff. Motocraft in this case.
Old Jul 27, 2008 | 05:02 PM
Pappy68's Avatar
would it make a difference if the motorcraft plugs are for a supercharged engine? cause they are the only ones i can find
Old Jul 27, 2008 | 05:09 PM
jbrew's Avatar
Post the numbers and we can tell you
Here's the list -
http://www.autopartswarehouse.com/se...20Ford%20F-150
