Fuel Pump Problems?
Old Jul 31, 2008 | 09:41 AM
rherrin3's Avatar
Fuel Pump Problems?
Hello!
I had to change my Serp.Belt and now my '97 F150 won't start. It will turn over fine. How can I tell if my fuel pump is faulty and exactly where is it located. I turn the key but can't hear the fuel pump. Any other trouble shooting ideas are greatly appreciated.
Old Jul 31, 2008 | 11:27 AM
joshmac4.6's Avatar
If it won't start after the change, you could have broken or unplugged the crank or cam position sensors. Or possibly popped a fuse somehow. The fuel pump is in the tank, it should run for about 2secs when the key is turned to the on pos. lay under the truck and listen while someone turns it on.
