New Radiator and some extras
Well as most of you probably saw my stock radiator started leaking on me. I ordered a dual core radiator from ebay. The trans cooler fittings were wrong so it was just an excuse to get an external cooler.
heres my original thread https://www.f150online.com/forums/sh...d.php?t=338754
making the trans cooler bracket
trans cooler mounted vertically in front of condenser. mounted like this it is as tall as the condenser is.
new dual core radiator fabbing up some new efan brackets.
since then i finished installing all the intake and other parts that i pulled out. and cleaned up the wiring :o
everything seems to be running good and cool
-Patrick
-Patrick
I installed a new trans cooler, and radiator. I did not use the OEM style trans cooler in the radiator side tank.
yes the "mushroom" caps are the trans cooler quick disconnect line fitting.
If you look closely in the last blurry picture you can see the two new trans cooler lines running forward under the radiator. I can take more specific pics of that this weekend.
got a question, though...do you think your new tranny cooler will be enough by itself without the in-radiator cooler?
Externally mounted transmission coolers are often referred to as auxilliary coolers. Usually their purpose is to "help out" the in-radiator tranny cooler, not replace it altogether. Since they are air-to-fluid coolers, I don't see how even the best auxilliary cooler could completely replace the in-radiator fluid-to-fluid cooler.
However...I don't pretend to be an expert on this subject; perhaps Mark Kovalsky (member here) can chime in here. If I remember right, he is or was a FoMoCo transmission cooling engineer.
on the 05+ f150's and lightnings the transmission coolers were no longer put into the radiator because of heat soak from the high coolant temperatures that would just bake the fluid causing the transmission to run hot. even the super duty trucks went to large external coolers because they are more effective.
got it used for 17 bucks
Great minds think alike? :-p
Looking at all these different posts has given me some great ideas for when my wife comes back from her trip as to how to permanently mount my Perma-cools!!
