Shifter popped; wont shift
So I backed out of my driveway the other day. Put my truck in reverse and everything was fine and normal.(auto tranny) When I went to put my truck in drive, I heard a pop. My shifter began dangling and now I can only shift it from reverse to 2nd gear. There is also a lot of play with my shifter. I cannot put it into park at all. This means I cannot remove my keys from the ignition either. I crawled underneath and manually put it in park but I still cannot remove my keys. Does anyone know by chance what is wrong? Is it a broken shifter do you think or steering bushings? I think that my shift cable is ok. Any advice would be greatly appreciated.
'97 f150 4.6
auto tranny
'97 f150 4.6
auto tranny
That has happened a couple of times to an E150 van I drive at work. Sounds like something is broken in the column. The last time it happened to me, some metal parts fell out from under the dash. I don't have any more details as I just had our mechanics fix it and didn't ask them what it was.
Same thing happened to my 04 Navigator a few months back. I had to get the airbag suspension rebuilt and took it to the Lincoln dealer. Got it back with a broken shifter and didn't make it 10 feet before it broke. The tranny and all of the mechanical stuff was fine. It was just a stupid plastic piece of the shifter itself that broke. Sounds exactly like what your problem is. My shifter had a ton of play in it too when and after it happened.
