Tuning Issues...
Old Nov 6, 2008 | 02:28 PM
baticus's Avatar
Tuning Issues...
Alright, I just purchased a 5.4 for my 2000 F150. And from reading throughout all these other 5.4 swap threads, I have a few questions regarding a tune for it. I know about the transmission tune, because my truck has an M5OD, but I was more concerned about the engine tune, I know you can get a tune to delete the EGR, but I was wondering about the cats? I dont have any emission laws where I'm at. Would it be worth deleting the cats? I'm also currently ordering a set of long tubes, as well as a cold air intake, and new internals as it will eventually be getting boost down the road.
Also, what are some good aluminum heads? I haven't been too bothered to look yet, as I haven't torn into the engine yet.
Old Nov 6, 2008 | 02:35 PM
Matts ford's Avatar
you might as well do all the mods at once. otherwise you'll be paying for new tunes every mod 1 at a time. you can delete the cats but i would reccommend you put 2 high flows in place of the front cats. and you wont need a tune for them.
Old Nov 7, 2008 | 09:09 AM
baticus's Avatar
I will be doing all the mods at once, aside from putting boost to the engine. Basically, I will be building the bottom end, and putting aluminum heads on. Installing it, with a tune for the egr delete, and possibly the cat delete. I plan on driving it in this state to make sure there are no drivability issues, or no problems, then eventually putting a supercharger/pro charger on it.
Old Nov 7, 2008 | 01:37 PM
phil6608's Avatar
Your truck has aluminum heads on it!
The don't make an aftermarket head for these trucks yet,,,best you can do is have them ported and polished and put a better cam in them.
https://www.patriot-performance.com/( the cheapest ones but they had problem)
http://www.totalengineairflow.com/( that's what I'm running)
http://www.foxlakeracing.com/
Oh yeah,,,I just saw that Trick Flow is coming out with the first aftermarket heads for the 2V soon!!
http://forums.modulardepot.com/showthread.php?t=109974
Phil
