- Need help with starting problem....
- Fuel filter sizes?
- Bad spark cables/dist cap? Funnnn....
- Truck is slow, real slow
- missfiring :(
- engine tap
- THEFT light blinking....FIXED
- EGR error codes
- 2002 4.6 into a 1997 F150
- Is a Shaker intake any good?
- popped a plug, have a question.
- COP and plug change comple, now Theft Light?
- Intermittent start problem
- What 'built ford tough' really means
- Engine issue
- Edge Evolution for 99 f150
- Dieselling effect
- HELP - IAC Problems
- Engine Coolant Sensor problem
- 4.6 starting issue
- 2005 F150 starter removal PROBLEM
- Meziere's WITHOUT Pulley?
- left turn power loss
- GREAT Oil Info...
- F150 Hot Start Problem
- are all supercrews with the 4.6 like this?
- Hard starting
- knocking injectors?
- Vacuum Question
- key lock cylinder
- Coolant temp / tranny temp with Scanguage
- Fuel Injectors...help Please...
- Semi Synthetic Motor Oil
- more power
- testing catalytic converters in situ?
- where is my engine coolant temp sensor
- What Bosch Plugs Can Do!
- Testing posting
- Help with check engine light
- Engine light came on at 73.5k
- **All about Passenger side /starter head gasket leak**
- Oil Filter on 2008
- Lucas Fuel Treatment
- '01 F150 Screw Bucking and having issues HELP!!
- Vibrating noise under my right dash
- Oil under front left wheel well HELP
- 07 5.4l Battery Voltage
- Dual Fuel Vehicle
- Strange High RPM
- 5.0l into 99-f-150 v6
- Will Ford blow it on the new light diesel?
- mis-fire...very stumped
- Missing Only after warmup
- what!?!?!?!!??!?!
- Engine whines when revved
- changing plugs on an 03
- running 93 oct before plug change. Will it help?
- 2000 4.6 code
- 04+ 5.4l question...
- mustang throttle body on a f 150?
- FYI: Replacing the fuel pump is a royal PITA
- Possible main bearings going out/low oil pressure
- Is BP gas best for plug issue?
- fuel filter question
- AC works better now
- which o2 sensor should i replace
- MotorCraft Oil & Engine Varnish?
- Hydrogen and Longevity
- over drive...
- Service manual for 97
- Repair Manual
- engine missing!!!!!!
- coolant
- how many o2 sensors on a '02 4.6 (romeo)?
- 4.6 engine 11.5 mpg
- Need belt help/advise Asap
- Bad Start Up
- Sudden engine rev
- Code 34 after cleaning EGR, still CEL 41
- Royal Purple
- Engine Knock at low speeds
- ignition trouble
- 3V 5.4l Quits
- trouble codes P0133 and p1260 on f150
- PI head swap
- Need some help?
- got my globals, still need some opinions
- Loss Of Power?
- Loss Of Power?
- Eight spark plug thread Pi Heads 2005-2006
- New Radiator and some extras
- 5.4 Horsepower
- Need Diagnosis HELP!!!!!
- '06 5.4L Engine Hesitates...
- Help! Washed engine, changed plugs, runs like garbage!
- Power washed Engine
- owner manual site?
- Indiana Jones Or Batman Movie Sequel $250 In Movie Gift Cards
- $500 TARGET Gift Card
- Viper Engine
- Check Engine Light
- DPFE Sensor melted on '01 5.4L
- thermostat
- Engine won't start after replacing belt
- Truck warms then dies. Any thoughts?
- P-1SC 1 Tranny 0
- Synthetic Motor Oil
- 02' F250 5.4L Pinging
- Fan Clutch?
- '98 4.6l with 115K. How extensive tuneup would you do?
- ok why is it that fords...
- engine revs by itself....need help asap
- I am thinking Cam?? What else?
- Battery dead after sitting for one week?
- What ELSE can I do for more power?
- Gas mileage, Wtf.
- 97 f150 4x4 engine matches
- cant find problem
- need a little help real fast
- Engine dying
- Engine upgades to 97 F150 5.4
- Block and head numbers on 4.6 engine?
- Trouble starting my 5.4L in morning
- Missfire code P0300
- Maf Sensor Cleaning
- my battery light goes crazy at 4k rpm
- O2 sensor 92 5.0 F150 dead after 2 years?
- check 02 sensors?
- overheating issues..
- Setting Timing '97 F250 HD 5.8
- Oil Grade Question
- 5.4l problem
- Gas Mileage questions
- Engine vibrating when AC is on
- 92 5.0 no start
- 2005 Fuel Injectors
- no start!
- Help with oil pressure
- all the parts i need for spark plug replacement?
- spark plugs 5.4-When to change??
- old timers--relatively speaking of course
- Changed my plugs??
- Can someone tell me where this wire connects?
- 2000 5.4 plug change
- Sluggish when hot...
- Free $1500 IN GAS GIFT CARDS
- sparkplug wire popping off!
- More Power
- Truck wont start
- Aww crap!
- Rough Idle
- Help can i damage my 03 lightning
- Push Rod Problem
- F150 4.6 rough/surging idle. Low compression.
- injector question
- '97 4.6 for newer PI 4.6
- 99 F-150 missing
- Bent Push Rod
- 05 Running rough when cold
- Where to wire gauges?
- spark plug paranoia
- Check Engine Light - OBD-II codes thrown and now I'm confused
- Who's using E85 Ethanol in their truck? (info needed)
- Starting problem's HELP ME!!!
- HELP! Coil pack to plug wire order?
- Oil: Who uses what?
- oil leak help!
- P2006 Error Code Help NEEDED
- battery wires
- Tundrowned
- My #1 (frontmost passenger) coil flew out/broke off.. spoke, puff.. why?
- rough idle after warm engine start (intermittent)
- P0401 and P0402
- Trouble code
- SES/CEL code reading
- Engine Light on after mudding
- Amsoil or Royol Purple
- Where is the vacuum reservoir located on my 07 5.4?
- Radiator/heater hoses
- Odd noise when I turn of the engine
- 4.6 engine gone bad?
- No High-end HP after plug change
- Efans = Dead Radiator
- 5.4 Heater Hose - How hard a job?
- 02 f-150 misfire only under load
- 99' f150 fuel pump relay bad/suspect?
- Missing and now dying, NO CEL, 2000 4.6l
- changed plugs, now runs rough when in gear
- Is there such a thing as to much power?
- Urgent Please Help: Could I damage the lifter rods or other engine parts?
- 5.4 engine knock
- 50 shot on stock 4.6?
- changing fuel filter
- Online Ford Factory Parts Shop Suggestion
- F-150 with mild vibration at idle
- My mech says i need all 4 O2 sensors, Is this right?
- New Injectors and MAF
- 07 F150 Check Engine
- Hissing Sound During Light Acceleration
- What are the sorriest engines out there?
- My truck ran HOT...
- What the hell?
- 2001 Ford F150 Triton V8 XLT service engine soon light
- spark plugs 5.4
- 460 or stroker
- No power when hot
- The Score: Drew - 8; Spark Plugs - 0
- #4 misfire
- Fuel problems maybe
- Amsoil
- Triton firing order
- lucas
- Cam Phaser / Lifters update
- Power Steering Pump Installation
- 1999 Exp XLT 5.4L (8 cyl) Oil Pump Failing?
- whats the best for our trucks
- engine question
- Breaking in my motor ???
- Toughest engines ever built
- 2003 ford expedition
- New plugs?
- Loss of power on 5.4
- 5.4L intake manifold :(
- charging System Q&A's
- P0401
- spark plug 5.4
- odd knock in engine
- 4.2 to 4.6 or 5.4
- 5.4L Spark Plug Blowout
- 5.4 vs. all others
- service engine soon
- Fuel Filter Question
- 30,000 Mile Service
- 05 SC Engine Problems
- canged plugs, wont start. Now what did I do
- Intake Manifold Compatiblity
- My 1997 5.4 shutters and shakes
- Another injector ??
- what would you pay?
- Swapping a 5.4L Lightning Motor in place of my N/A 5.4L
- WOW!!! found some power...
- Oil Pressure - Did I hurt it???
- Spark Plug Wires
- 99 F150 4x4 4.6L -- ENGINE REPLACEMENT OPTIONS
- New Gas E-30
- Engine ticking & knocks at High RPM's
- 93" 5.0L, does anyone know what this is?
- Finally got to drive one with a 4.6L
- P0442 - Evap System small leak HELP
