P0305 and DIY - What to Expect?
Old Dec 28, 2016 | 12:33 PM
Todd Richards's Avatar
Hey all - I've got a 2003 F150 5.4 V8 with about 145K miles. I got it 4 years ago with about 115K miles on it and, while it was in good shape when I got it, I don't have a history or maintenance.
Yesterday I went to jump in after it sat for about 4 days, and although it started immediately, it was chugging a little. I drove it anyway, and after about 20 minutes the check engine light started coming on (mainly during acceleration). Every time I made a stop and turned the engine off, it started right up again. But by the time I got home (about 45 minutes and 20 miles later), the check engine light was on.
I have a diagnostic tool, and it showed the P0305 error - Cylinder 5 Misfire. After doing some research (including here), I'm going to start with new plugs and coil packs. (I could also smell a little 'rotten egg' smell, which research said could be related to the misfire.) I found everything on Amazon for $100. I also called the dealer to see if I was heading in the right direction, and while they wouldn't guarantee it, they said it sounded right. To change the plugs, coil packs and do injector cleaning, they want $800. So I think it makes sense for me to order stuff and roll up my sleeves. While it's been a while since I've worked on vehicles, I believe I'm skilled enough to change these out.
Here are the plugs and coil packs that I am ordering if anyone has any thoughts.
Just looking for any thoughts, tips, or suggestions before I take this on this weekend?
Thanks in advance!
Todd
Old Dec 28, 2016 | 01:04 PM
Correct plugs, but those coils are garbage. The ONLY cheap coils I'd consider would be from Araparts. Otherwise, stick with Motorcraft, Delphi, or Denso. I would change just the plugs and see how it responds. Do not use antiseize and torque the plugs to 28 ft/lb. Clean the coil boots thoroughly and use dielectric grease.
Old Dec 28, 2016 | 01:11 PM
Thanks for the heads up! I chose those coils because they got great reviews. But I haven't ordered so I will wait. I will try plugs first and see what happens. Would it seem odd that a plug would go bad "overnight"? Thanks for the feedback!
Old Dec 28, 2016 | 04:03 PM
Cheap Chinese knockoff coils are always a crapshoot.
Old Jan 3, 2017 | 03:22 PM
Just a quick update. I changed the plugs out over the weekend, cleared the error code from the system, and it seem to be running good. OK, it's actually running great. I checked the gap on all of the plugs as I pulled them, and they ranged from .065 to .076. This has been on my list to do for a while, so I guess I just needed to be nudged!
Old Jan 3, 2017 | 08:48 PM
Roadie's Avatar
They were likely the original plugs. I ran my OE plugs to 119k and the engine still ran great.
