Need major help!
Old Jul 5, 2016 | 08:17 PM
Rebelman95's Avatar
Need major help!
I have a 2004 F150 v8 5.4 with roughly 230k on it. The truck started misfiring in cylinder #1 and the check engine light started flashing so I hooked the reader up to it. I'm getting codes P0011 camshaft positioning over advanced, P0012 camshaft positioning over retarded, P0340 camshaft sensor A circuit bank 1, P0345 camshaft sensor A circuit bank 2, P0301 misfire cylinder 1, B1318 battery voltage low, B2296 SRS Impact sensor status.
I have no idea what the problem could be. I've heard it's possible the low battery voltage could cause all of this. Is it true?
Old Jul 5, 2016 | 08:42 PM
Roadie's Avatar
I'd check the battery voltage low issue first. Make sure the battery and charging system is operating properly. If the voltage is indeed low, that might cause other problems.
