Best HP improve for 2001 5.4?
Old Oct 24, 2016 | 12:10 AM
Thundertek's Avatar
I'm on a budget of $5,000, what's best improvement for a 2001 F150 4X4 with 250K, assume I'm replacing with a rebuild long block with PI heads, what else should I do? Please send me ideas. Thank you
Also have a KN Filter and Headers, will add a programmer ? Type?
Injectors?
Old Oct 24, 2016 | 08:56 AM
Roadie's Avatar
To get real power improvements out of the normally aspirated engine, you will need to change out the heads/cams along with everything else that it will need such as throttle body, injectors possibly, intake, custom tune, etc. Your 01 has the PI heads as you know I'm sure.
Old Oct 24, 2016 | 09:40 AM
Thundertek's Avatar
Thank you Roadie, If I'm buying a remanufactured long block with the PI heads for $2,600, would I be better served buying short block and going with Higher Pro heads and cams, HP throttle body? Anticipate changing cams would change tune and and hours to install?
What's your guess if I use stock heads, KN intake, headers, injectors, programmer.
Could I get close to 375HP my goal is 400hp but seems like might be hard to achieve with my budget?
Old Oct 24, 2016 | 10:11 AM
Roadie's Avatar
Using stock heads, the only thing that will give you that kind of hp increase is a supercharger. the hairdryer type may be the least expensive.
Old Oct 25, 2016 | 07:33 PM
guyina4x4's Avatar
wow surprised the KN didn't do it for you, LOL
you need the power for what? towing or just feeling the power?
Old Oct 25, 2016 | 08:25 PM
A K&N doesn't increase horsepower, it just sounds good and sucks more dirt into the engine. The stock intake is a decent cold air intake.
Old Oct 28, 2016 | 11:19 PM
guyina4x4's Avatar
that's why I put the LOL
it's funny because his current mods probably actaully made his trucks performance worse.
