PDA
View Full Version : Transmissions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50
  1. Found mushroom in tranny pan
  2. Quick question
  3. 4R70W transmission pans?
  4. Vibration in rear end
  5. Tranny Flushing....anyone tried this???
  6. 6-spd kit for Lightning?
  7. Two or three second delay from R to D
  8. Changing fluid after 100k miles
  9. TransGo Shift Kit Install
  10. What Transmission
  11. Howling Drivetrian
  12. Leaking Transmission
  13. Transmission cooler standard equipment on a 1998 F150 XLT?
  14. 97 F-250LD Clutch question
  15. Tranny Question (Normal or Not)
  16. 4r70w fluid interval changes...
  17. Towing
  18. Opinions on upgrading tranny cooler?
  19. Is ProLine and Mercon the same thing?
  20. Friction modifier ??
  21. 4R70W transmission loss of overdrive
  22. Neal (Guru), Baumann
  23. trans id
  24. Keeping up with a Rice UV
  25. Trans acting weird need help...
  26. What's the difference in all these Trannys?
  27. d**n shuddering 4r70w..@^$%#
  28. Shift kit fially in !
  29. VIbration at 60mph
  30. F-150 Towing Problems
  31. Shuttering E4OD 1993 ????
  32. When to change gears??
  33. Ok, where is the code for the tranny on the doorjamb?
  34. Shift Kit VS Reprogramming?
  35. Hard Downshift Question
  36. Shift Kit For V6?
  37. Question on 97 F350 Tranny
  38. Tranny Temp Gauge Question
  39. Anyone here know much about mustang T-5's?
  40. 4R70W service and upgrades
  41. Stock Gearing and Trans. cooler question
  42. MerconV vs. Dextorn II?
  43. speedo fix on 99 F150
  44. How much should I bring?
  45. What Tranny Fluid? Who is Right?
  46. strange noise
  47. What gear?
  48. Tranny shifting hard into 2nd/ Please Help!
  49. Synthetic yes...but what kind?
  50. E40D to C6 swap???
  51. A rookie 4X4 question??
  52. tranny slipping ????
  53. Over Drive On/Off?
  54. 3:73 or 4:10's?
  55. Trans fluid change. Which fluid should I use??
  56. Thanks AjRagno
  57. Opinions on shift kits
  58. up hill
  59. In-line filter for 4R70W
  60. 97-98 speedo correction gear
  61. problem or not?
  62. AjRagno a couple of ????
  63. Auto Transmition dead at 2500 miles!
  64. Tranny Fluid Change Questions
  65. Manual fluid change and synthetics?
  66. finding out which transmission I have
  67. overdrive off around town??
  68. Tranny crapped around 112mph!!!
  69. SD 4by auto trans will not shift HELP I am on vacation !!!!!
  70. machanic question on 30k tranny flush
  71. Bad 'whirring' sound from around Converter ?
  72. 2nd time my trans took a dump on me........
  73. 4r70w transgo install
  74. Funny noise when giving gas to go up a hill
  75. ? for 2kExpi
  76. Will this converter work???
  77. weird problem
  78. O/D on off switch???
  79. shifting into 5th
  80. Tranny Type
  81. tranny shudder.....any one else with this problem?
  82. Towing "properly"
  83. FYI,Trans Fluid change Done
  84. Dealer forget to tighten my tailshaft...
  85. Tranny Gone-- 58,000 miles
  86. Replacing manual with automatic transmission
  87. 4X4 Transmisson Question
  88. 4X4 trouble...it won't catch....
  89. Switching to Amsoil Synthetic Trans Fluid
  90. Factory_Tech Question
  91. Transmission fluid change
  92. Trans-Go and what else?
  93. those with the 5 speed i need some help
  94. Mercon V info.
  95. Scary!
  96. transgo 4r70w question
  97. Has anyone experienced this....
  98. Do I have TC shudder?
  99. transmission model
  100. T-Handle
  101. Vibration
  102. 3-2 Downshift Click
  103. Trannie sucks
  104. Castrol 5W-20!
  105. F250 HD 6psd in a F150?
  106. Part time 4-wheel drive
  107. five speed problems
  108. transmission slip?
  109. What exactly is a shift kit...?
  110. tranny fluid
  111. Squeaky (sp) clutch..?
  112. Transmission
  113. Better Shifting
  114. shifter for 2001 5spd trans
  115. My experience w/ the mazda 5spd
  116. B+M ShiftPlus?
  117. Transmission fluid change from dealer
  118. Transfer case oil change easy --cheap
  119. shifter kit running 35s
  120. 4R70W 1-2 shift clunk
  121. rear end question
  122. Flywheel for a C-6
  123. Got stuck.. Need Info..
  124. clutch return spring
  125. Newby Dumb Questions...
  126. What is the most recommended Mercon V?
  127. Do you have this?
  128. transfer case fluid?
  129. leaking clutch master cylinder?
  130. Beefing Up the Manual Trannie
  131. transmission damage, low clutch fluid?
  132. torque converter drain/refill
  133. Ar ethe transmissions the same for the 4.6 and the 5.4
  134. manual tran. fluid change???
  135. Short burst of Noise at 10 to 15 MPH and coasting.
  136. Shudder problem fixed, but now 2nd gear doesn't work right!!
  137. Help with MYFORD.COM
  138. trns drain
  139. Do you have a shudder/chatter problem, too?
  140. A question for 97 4R70w owners
  141. How Much Oil?
  142. Quakerstate 4x4 Synthetic Blend ATF?
  143. Trans pan magnet 'goop' (pics)
  144. Planetary gear explosion.
  145. 4r70w?????
  146. When pulling tranny filter off,whats with the orange o ring?
  147. Transmission under/over
  148. rear diff change question
  149. 4x4 stuck in 4x4low
  150. Removing the boot from the plug.
  151. Tranny shimmy (thanks)
  152. Anyone tried a syphon pump thru the dip tube to drain tranny?
  153. Cost on a 4R100
  154. Groan/Knocking under moderate acceleration?
  155. Shudder noise, 3rd to 4th.
  156. Harsh 1-2 Upshift
  157. very rough shifting
  158. tranny temp gauge install
  159. T-5 or tremec swap into 99v6 5 spd?
  160. 4.2 V6 w/manual tranny grinding 1/2 shift, HELP!!
  161. My overdrive light keeps flashing
  162. 5 speed/ 2-3 noise
  163. Need Manual Tranny maintenance how-to?
  164. Trans squeals on shift
  165. New Transmissions any time soon?
  166. Searching among gears
  167. 462 Lincoln Motor, need a standard tranny for my 85 F150
  168. A Question About Transmission Shudder
  169. Tranny Temp Guage/Transfer Case Guage??
  170. trannys aren't cheap!
  171. Hard shifting 99
  172. Question for Factory_Tech...
  173. Wolf's Head ATF
  174. In Need of a Tranny Cooler??
  175. 4r70w Shift Kit
  176. HOW TO: Manual Transmission Ignition Lock Lever Removal
  177. E4OD fluid?
  178. In need of help!
  179. 4WD question on 94 F-150
  180. Will mustang gt trany bolt up to a 4.2?
  181. Transmission Noises
  182. Inherient Transmissons problems with Ford
  183. Transmission Drain v/s Machine flush
  184. 2001 F150 Transmission Noise
  185. differential question
  186. speed sensor same on A/T and M/T?
  187. Flashing overdrive light
  188. Transmission vibrates from third to fourth gear.
  189. how many miles can you get from a A/T
  190. A piece of advice needed
  191. 35 in. Tires hurting my truck?
  192. Stock to 4.56 w/ Precision Gear?
  193. Clutch Adjustment
  194. speedometer zero
  195. vibration while decelerating
  196. Overdrive slip???
  197. speedometer failure
  198. 3.03 to 3.73
  199. Transmission Type
  200. Trans Rumbles
  201. Trans Code "U"
  202. Overdrive switch problems
  203. cooling upgrade?
  204. NEED HELP!! Superlift Truspeed and Tranny Harness ID
  205. I would never have made it as a pipe fitter
  206. tranny noise at re-acceleration(((
  207. Transmission Fluid
  208. Leak!!!!
  209. where to get shift kit ?
  210. Transmission ID site.
  211. Blowing seal
  212. Transmission Pan Size?!?
  213. First gear doesn't engage on my automatic....
  214. 2001 Ford F150 4x4 Problems Clutch
  215. Torque Converter Clutch Slipping?
  216. 4th gear pulls like 3rd
  217. going from 3.55 to 4.10
  218. Got Tranny / Clutch serviced, now my truck (5 spd) vibrates and shakes.
  219. Speedometer gear
  220. Changing Shift Points
  221. Transmission Fluid
  222. Is This Tranny Shudder ??
  223. 4R70W with MERCON? Is it possible?
  224. tranny fluid change questions
  225. Dakota 5 speed
  226. My automatic needs a clutch!
  227. Vibration when shifting in fourth gear.
  228. What kind of transmission do I have?!?!?!?!
  229. 5-speed manual tranny problem.
  230. Pan Gasket
  231. Torque Converter, lock...unlock!
  232. Is this a problem? (tranny)
  233. Tranny Slipping
  234. sloppy shifting
  235. Transmission Temp Guage
  236. Need help fast!!!!!
  237. RPM and gear ratio
  238. Trans Temp Guage
  239. Torque convertor and towing
  240. Whats my Supercrews gear ratio?
  241. Speedometer Gear Failure every 3 months
  242. aftermarket shifter good or bad idea
  243. Which shift setting!!!!
  244. Tranny ?
  245. gear ratios
  246. speedometer
  247. Shift or get off the ...
  248. 4R70W (AOD) vs. 4R100 (E4OD)
  249. Good Deal...
  250. additives
