FYI,Trans Fluid change Done
Old Mar 10, 2002 | 05:17 PM
2fords's Avatar
Thumbs up FYI,Trans Fluid change Done
Completed my trans fluid/filter change yesterday at 26,500k miles, including TC. Pretty easy, but messy as all hell. I used a purolator filter and aamaco semi syn mercon V, not really the brand of fluid I wanted, it just worked out that way, it's manufactured by exxon/mobil corp. The filter doesn't fit too snug in there, but the factory one didn't either. It seems to shift a little smoother now.
If you've been putting it off you should go for it, it's easy, nessecary and your truck will love you for it
Old Mar 11, 2002 | 03:37 PM
dfwbmw's Avatar
How did you drain the TC? Pull the cooling line and run the engine or pull the bolt off the TC. Thanks
Old Mar 12, 2002 | 10:30 AM
p_ferlow's Avatar
I pulled the bolt off the TC. Worked fine. Takes an hour to drain though.....drip...drip....drip.
Old Mar 12, 2002 | 05:45 PM
2fords's Avatar
That sums it up, TC drains pretty slow. P_Ferlow has a link to some really good directions, recommended reading before your change.
Old Mar 12, 2002 | 07:11 PM
dfwbmw's Avatar
Yes I did read all the post and links. I was just wondering what the "field" operatives were doing. That to me is the real test!!
Old Mar 14, 2002 | 04:18 PM
2fords's Avatar
I know what you mean. Trust me, If I can manage to complete something, then's it's idiot proof
Old Mar 14, 2002 | 04:29 PM
2fords's Avatar
One more thing
Total cost: 12 qts fluid=$30, filter=$17.50
I highly doubt you could find a dealer to do it for less than $50
Besides by doing myself I know I got a quality filter and more importantly I know Mercon V was put in.
Old Mar 14, 2002 | 11:38 PM
p_ferlow's Avatar
2Fords
Hey... thanks for the compliments!
Old Mar 18, 2002 | 01:42 AM
Bassdog's Avatar
how is it done
I'm at 30k and where are those directions that P ferlow mentioned. I've never attempted this but it would be good for me. Please tell me as soon as possible how it's done as I will be leaving in a few days. Thanks guys. Congrats. On doing your own job. I guess I'd be able to do it too! Dan
Old Mar 18, 2002 | 03:41 AM
Mach1's Avatar
Dont forget the shift kit, the deep pan, and the synthetic oil....
Mind as well bulletproof it while you are there..by the way this is the vehicles weak point....
Old Mar 18, 2002 | 04:21 PM
p_ferlow's Avatar
http://members.shaw.ca/pferlow/transmission_oil.htm
These are my instructions. Use at your own risk.
If you're a member (joining is free), www.f150world.com also has a good tutorial on the same procedure.
Old Mar 18, 2002 | 10:52 PM
HOSRACN's Avatar
i was just at ford, they suggested i get it done, $400+ for them to do it. i think i will do it myself.
Old Mar 19, 2002 | 09:29 AM
p_ferlow's Avatar
I guess so eh. $400+ and US$?? Holy cr*p.
You can save about $360+.
Old Mar 19, 2002 | 11:51 PM
FamilyRide's Avatar
For $400 I'll do it, with Amsoil, filter and toss in a shift kit.
Old Mar 25, 2002 | 03:59 AM
KYFordFreak's Avatar
FamilyRide
I could have swore at one time yo usiad you replaced your power steering fluid with Mobil 1 ATF, is this correct? I know the PS takes Dextron/Mercon but I wanted to know how the Mobil 1 worked in the PS and if it helped any. I hate search being down and I 'll keep looking bt I wanted to ask you also.
