O/D on off switch???
Old Mar 14, 2002 | 11:36 AM
Redbone's Avatar
The 5amp fuse that controls this switch keeps blowing. I figure its probaly a ground problem. But I'm curious if anyone else has experianced this and if so, what did you do to fix it?
I tow my boat 3 or 4 times a week, always with the O/D turned off. I go thru a fuse a week. It's getting to be a pain in the butt to keep replacing them.
Thanks in advance for any info.
Redbone.
Old Mar 14, 2002 | 01:39 PM
AjRagno's Avatar
This is a very common problem.
Look for a bare/ungrounded wire inside the shift lever leading up to the Overdrive ON/OFF switch.
Before you begin, disconnect the battery so you don't blow any other fuses.
