Tranny Temp Gauge Question
Old Mar 30, 2002 | 07:09 AM
Geeky's Avatar
I need to install a tranny temp gauge on my '00 f-150. I really don't want to use a pillar pod because I like the grab handle on my side.
Question: Who and where can I get a decent pod and gauge? I would rather mount it under or on the dash. Any ideas would be appreciated.
BTW I did research in history but ran into some dead links etc. and it became a major PITA.
Old Mar 30, 2002 | 11:31 AM
Neal's Avatar
Cool
HI!... GEEKY : AUTOMETER makes a column guage that might be just what you want. There's a pic below. Also use a AUTOMETER "MECHANICAL" temp guage. It is more accurate than the electrical style. Make sure you install the probe in the OUTGOING tranny line before any of the tranny coolers. IMO do not install it in the pan or in the casing of the tranny it'self. This causes HEAT SOAK and will give you inaccurate readings. This is my set-up on my truck. :::
https://www.f150online.com/galleries...4-793-6938.jpg
https://www.f150online.com/galleries...4-793-6939.jpg
https://www.f150online.com/galleries...4-793-6937.jpg
https://www.f150online.com/galleries...4-793-7167.jpg
Old Mar 31, 2002 | 02:24 AM
IAmGeeky's Avatar
Thanks Neal,
Old Mar 31, 2002 | 05:03 AM
IAmGeeky's Avatar
One more
What a hassle! I guess I'll call them Monday. I want exactly what you showed but there site has too many choices. Does that mean I have to run a fluid line up to the gauge or does it go electrical from the sending unit?
Ahhh, patience you must have Grasshopper. LOL
Old Mar 31, 2002 | 11:21 AM
Bubbadewsky's Avatar
Talking Hello Neal
Is that guage and mount an exact replacement for our steering column (color and texture) Do you have part #s for the mount and gauge---- Does the present one just snap off?
Dave
Old Mar 31, 2002 | 03:01 PM
Neal's Avatar
Cool
HI!... The "MECHANICAL" guages use a probe sensor and capillary tubing containing a gas. As the probe temp increases it pushes on the gas in the capillary tubing which in turn move the needle on the guages. A oil pressure guage in "MECHANICAL" form does have a live feed to the guage. If you use a -3 braided line you will have no leaks or problems. Stay away from the nylon tubing. I believe the AUTOMETER steering column guage pod replaces the upper factory one. It's held together with 2 screws from the factory.
Old Mar 31, 2002 | 04:38 PM
IAmGeeky's Avatar
Dead horse?
Neal, I’m trying to figure out what the significance of the 2,3 and 4th pictures you posted is. Is that not the regular t cooler like mine has? And what is the filter picture about?
I assume that the plastic on the pod is black. I know you can get dash paint at the Ford house that matches pretty good. I wonder about Pep Boys? I think that's really going to look good.
Old Mar 31, 2002 | 07:30 PM
Neal's Avatar
Cool
HI!... GEEK : (1) = AUTOMETER temp manifold. Where the mechanical guage's sensor probe installs in a "IN LINE" set-up.
(2) = Aftermarket PERMA-COOL auxilary tranny filter.
(3) = A PERMA-COOL 10" x 14" ALUMINUM tranny cooler. I got rid of the factory's garbage cooler and installed this one with a 10" SUMMIT electric fan kit.
Old Apr 4, 2002 | 09:50 PM
Flyfisher's Avatar
Question
Neil, I have enjoyed reading your posts over the last year and simply amazed you have enough time to do what you do. Any way, I agree with you on going opinion regarding where to place your temp. sensor. ( in the cooler line coming out of the hot tranny). One ignorant question. Which line is the un-cooled line.
I have a 4r100 tranny.
Your thoughts would be appreciated.
Old Apr 5, 2002 | 09:03 AM
Mark Kovalsky's Avatar
The un-cooled line is the one from the front of the transmission. The cooled fluid is returned to the rear of the transmission.
Mark
Old Apr 6, 2002 | 09:02 AM
Flyfisher's Avatar
Thumbs up
Thanks for your help mark.
Old Apr 8, 2002 | 09:04 AM
IAmGeeky's Avatar
Single pod for steering column out of production
The lady at Autometer told me I might be able to get one in a couple of months....Bummmer
Old Apr 8, 2002 | 12:23 PM
p_ferlow's Avatar
Are there any single or double pod mounts that fit the A piller where the whole thing is one piece that replaces the factory plastic? Those ones that fasten to the factory plastic piece look kinda tacky.
