AjRagno a couple of ????
Old Mar 19, 2002 | 01:31 PM
Redbone's Avatar
You had replied to me that the O/D switch blowing fuses is common and to Look for a bare/ungrounded wire inside the shift lever leading up to the Overdrive ON/OFF switch.
My question is how do you get inside the shift lever to fix this problem?
Thanks.
TB
Old Mar 19, 2002 | 08:16 PM
AjRagno's Avatar
The first step when working on anything electrical is to disconnect the negative battery cable so you don't blow a fuse or kill yourself.
Pop off the O/D switch at the end of the switch lever and disconnect the 3 wires (keeping track of where each is connected).
Next you need to remove the gear shift lever. Put the truck in 1st or 2nd gear and you'll find a pin at the base of the shift lever that holds it to the steering column. It may be covered with a leather boot that has to be cut or pulled back to gain access.
When you remove the shift lever, it will expose the 3 wires leading up to the O/D switch. There are good odds that you'll find a hole worn through the plastic sleeve and at least one of the wires.
If you want a repair that will last; you'll need to replace all 3 wires with a thicker guage and protect them with a hard plastic sleeve at the base of the shift lever.
***You'll figure it out just fine, I'm sure***
Old Mar 20, 2002 | 07:47 AM
Redbone's Avatar
Thanks, AjRagno that is exactly what I needed to know. I can definatly handle it from there.
TB
