Friction modifier ??
Old Apr 7, 2002 | 11:05 AM
LE PEW's Avatar
Question Friction modifier ??
I asked this question elswhere but got no response. For those in the know, do you have to add friction modifier to Mobil 1 ATF ??
thanx in advance.
Old Apr 7, 2002 | 03:56 PM
max mitchell's Avatar
LE PEW-
The question probably confused people. The transmission only needs the specified transmission fluid. Friction modifier is added to the LS rear-end during normal maintenance.
Old Apr 7, 2002 | 04:02 PM
LE PEW's Avatar
Thanx Max, I have heard of people adding it to the tranny too but was'nt sure if it was needed or just an attempt to cure the shudder.
Old Apr 7, 2002 | 05:43 PM
LE PEW-
You're Welcome !! You're correct, it's an "attempt". Normal transmission maintenance doesn't require it.
