Vibration
Old Mar 2, 2002 | 01:43 PM
Fordified's Avatar
Vibration
I have a 2001 F-150 with the 5.4l and a 4R70w transmission. I have noticed a slight vibration while in drive and at idle. It is most noticeable in the brake pedal while sitting at a stop and it seems to get worse if I put the shift lever in L1. Also has a very light buzzing/humming noise that seems to go with it. If I shift into park or neutral the vibration/noise goes away. Any ideas what this could be? It seems to be worse when the engine is warm and the outside temperatures are below 45 degrees.
Old Mar 4, 2002 | 08:09 PM
supersport's Avatar
I had a similar problem until I cleaned my throttle body. I used carb. cleaner to cleaned as a routine maintenance and as a result the vibration at idle in gear seem to smooth out significantly. I hope this will help..
