View Full Version : Transmissions
- Dead clutch?
- F150 Flywheels
- transmission slip 1st-2nd
- Re:Factory Tech
- ATF Change
- Transmission took a Dump...
- locker quest
- 4R70W Factory Tech Valve Body
- Transmission
- Shifting Problems after Tire size change?
- New Torqshift trans info
- Tranny fluid...flush or just drain and replace?
- Never change fluid, what the heck?
- Should I start syn fluid now?
- Factory Tech
- Changing transmission fluid
- transmission
- Neutral Switch for 5spd?
- clicking noise
- How cool should my transmission run?
- Transgo Shift Kit
- New truck what trans?
- Downshifting
- 4R100 slipping
- tranny drain plug
- 5 speed troubles ahead???
- Whats wrong?? Tranny or rear-end??
- How do I find out what tranny I have??
- TransGo Performance Shift Kit ?????
- TRANSMISSION TROUBLE "gone"
- 5-speed stick moves when I give it gas?
- B&M Transpak
- 4r70w
- How do I find a Mechanic for gear swap?
- Question for Factory Tech
- Factory Tech.
- 97' 4r70w
- Mercon for my 4R70W?
- Which is a stronger tranny 4R70w or E40DE?
- trans slipping
- So did I get rip??
- 4.10's in front and back???
- minor automatic transmission problem?
- 91 vs 93 tcase?
- Filter Change
- Transmission Rebuild?
- Removing Tranny shift cable
- Mercon vs. Mercon V
- ??Tranny re-built: is it do-it-yourself job??
- Tranny Fluid/Differential fluid
- Transmission Service Help !
- 1998 transmission noise?
- Noise from 4x4 shifter?
- need another tranny oil cooler?
- Speed after 100!! ??? FOR NEAL
- Anyone have experience with.....
- tranny noise on 02 f-150
- Transmission temperature gauge
- 87 automatic trannys
- 1999 xlt reverse issues
- 4R70W Tranny question
- Torque Converter Question
- torque convertor change out
- Trans
- Ford to partner with GM
- Manual transmission difficult to shift!
- grinding noise down shifting into 1st
- computer reprogram?
- Cooler opinions?
- Which Tranny do I have?
- Leaking oil after flushing
- Shift Kit Problems?
- transmission harness
- Transmission Fluid Types
- wittom
- New valve body or shift kit?
- Clunking noise?????
- Do I have this right?
- I think my clutch is burning
- chattering??
- Superior Shift kits
- which tranny came with 5.0????
- Which Line Is which
- Transmission questions...
- trans. downshift problem
- Anything to worry about - 40 miles in 4H
- 1993 E4OD shudder question
- Tech Service Bulletins
- Found a trick for changing automatic transmission fluid
- 4r100 pump gear
- A/T upshift problem
- Has anyone driven their 4r70 hard?
- how to make my mile long shifter a shorter throw?
- Need help on Trans Temp Gauge install!?!
- In-Line Filter Kit
- Shift Technology Products
- tranny or something noise
- automatic transmission
- Full fluid change worked for me.....
- Transmission Noises - Sounds like Pressure Release - Help
- Guys with Trans Temp Probe installed in the cooler lines?? Need your readings...
- funny noise
- M5OD Swap Help
- 4r70w Blew With 4000 Miles On The Clock
- Correct fluid
- Torque converter drain plug on 4R70W
- How to adjust AOD TV Cable?
- differential gear
- Line Lock on 4.6
- Trans Temp Gauge--Temp Probe install ???
- ??B&M ShiftPlus Electronic shift improver??
- flush additive before drain
- Now only 4r70w
- Transmission Fluid "Flow"???
- Torque?
- Engine Swap - Need Help Please
- Transmission problem: 00' F150 XLT 5.4 V8 Supercab
- Tranny shfts very hard, and stutters when shfting
- Drill a hole for new plug before removing pan?
- Performance Automatics Valve Body
- annoing squeal
- troubled tranny
- how hard is it to change out the TSR.
- 01 SCREW w/Transmission issues
- Tranny Problem!!!!!! HELP??!!!!
- Transmission Filter / Fluid Change
- sonnax valves need more info
- Compression Braking???????
- F150 difficult to get out of Park...
- Fluid slightly burned, should I flush or drain?
- Ford bought it back
- Supercrew shifting problem! Help!
- Speed Sensor location
- Shifting question for mechanical gurus!
- Is this normal?
- Shift kits/enhancers for 97 auto.
- Converting to synthetics??
- Tranny Temp Guage Install ???'s
- Torque converter drain plug question.
- Major oil spill.
- Anyone seen this intermittent shifting problem?
- Transmission Filter Change?
- tranny shudder
- cv boot repair
- Tranny temps????
- Factory Tech, Your opinion please.....
- An expensive lesson
- Vibration in 4x4
- Transgo arrived
- follow up to overdrive light blinking
- Another Vibration Question
- Which Shift Kit?
- need help ID'ing this transmission asap
- Anyone with a Transgo kit in a 2002 F-150 ?
- Noise on shift during hard acceleration
- Help - Trango Check Balls
- '01 SuperCrew Question
- B&M Transmission Pan??
- fluid change
- Newbie q on ATF change
- 1st gear trouble at WOT
- Radiator fitting size?
- Explorer question
- Question for Factory tech and members
- DOH! Overfilled the tranny
- overdrive light blinking
- shudder during down & up shifts
- Freeplay in clutch pedal.
- Hard 2nd shift - hesitation
- PA valvebody is here!
- WOT trouble ????? HELP!
- 1997 v6 auto slipping
- a few comments please...
- Tranny Gauge installation question?
- What to do with this damned 5-speed???
- Clutch replacement
- Help Quick PLEASE!!!!
- 4R70W Self-Destructs in Passing Gear - 3rd & 4th Gone in a blink!
- trans cooler size??????
- Truck Shuts off change gears
- Shift Interlock Bypass.
- Thinking about a tranny cooler.
- 4R70W Service - Warranty Requirement?
- no downshift b/w 65-85kph
- Trans Temp Gauge Installed....
- driveline? vibration
- Petro to Synthetic Questions
- hard shift on the 2 -3
- ATTN: SCrew owners...PLEASE HELP
- is it possible to change a 5spd into a auto
- Which shift kit should I choose?
- Can someone help me with TSB info please?
- Shifts with Redline fluid
- Adjusting the Shifter lever Ford 1993
- clutch question
- Brown fluid = problem?
- Need Help...
- Transmission Temperature Guage
- auto tranny shudder
- Sonnax Valves in new transmission???
- Shift kit, valve body, line mods, etc, etc?? What does it all mean??
- Sound of a Manual
- 4R70W Service Schedule
- Which Transmission? (Newbie question)
- 4wd shifting ?????
- Towing with 3:31 rear end and 4.6L Tranny effect??
- Trans fluid additive...is it safe?
- c-6
- ???Does it make sense to install TransGo kit???
- Hello, new here and have fluid ?'s
- put in the new trans cooler....
- burnt clutch smell
- Is 15,000 mi. too soon to change???
- 5-speed, strange noise...
- Slipping Tranny-Help!!
- What Tranny?
- Trans-go kit part number
- Speedo calibration..need help
- Read this before Transgo shift kit install
- transmission cooler
- Need help, fast!!!
- Redline D4 vs Amsoil ATF?
- 5spd Question
- How much $ do you think
- Truck back at dearlership for the 10th time in 2 months.
- auto tranny / transgo question
- E4OD noise....
- sonnax valves?? WHERE TO GET?
- Delayed upshift after passing
- question....
- Housing crack
- Anyone replace rear seal on a 5spd.
- Wtf .093 ??
- Baumann installed O.D. not working
- Cooler Question
- Whats going one, Help!!!!
- 4R100 slipping??
- clutch????????????
- trans flushed and still have shudder
- How tight to tighten 5 Speed Drain/Fill plug??
- 4WD Pukes Fluid
- My trans says MERCRON not MERCRON V
- Should T/C be drained w/ every ATF change?
- Transmission shop
- Trans Additive???
- What warranty to get? (5-speed)
- trans 5-speed
- Is my tranny fried?
- Trans leak?
- Question for AjRagno (or wht does that mean)
