Correct fluid
Old Sep 27, 2002 | 06:37 PM
Crick's Avatar
Correct fluid
I am 99% sure I bought the correct fluid...it is the 1% that bothers me. So I figure that I will swallow my pride and ask...as opposed to damaging a good tranny
I got a quart of Mobil1 ATF fluid. On the back it says "Meets Ford mercron specs for use in 98 and later fords where type CJ or H is required. Also recommended for all cars and trucks specifiying Mercron".
Ok. The dipstick says to use Mercron V. No mention of Mercron V on the bottle.....
Thoughts....
Old Sep 27, 2002 | 07:34 PM
TexfordD's Avatar
check the manual...........l
does it mention it?
Old Sep 27, 2002 | 07:52 PM
01screw's Avatar
It is not the correct fluid, it must state Mercon V.
Old Sep 27, 2002 | 08:45 PM
LE PEW's Avatar
Absolutely right, Mobil 1 is Mercon compatible but not Mercon V.
Sorry to deliver the bad news but at least you found out before you poured it into the trans.
Good luck
Old Sep 27, 2002 | 10:24 PM
f150intally's Avatar
Is there a Dexron equivalent to Mercon V. Like, is Dexron III compatible with Mercon V?
THanks.
- Jay
Old Sep 28, 2002 | 07:49 AM
Crick's Avatar
:o
Good thing I asked!
I will take it back and look harder. I didn't see anything that said mercron V on the shelf. Since what I bought is synthetic tranny fluid, and I believe that mercron V is synthetic too, I thought I had a match.
Thanks everyone!
-C
Old Sep 28, 2002 | 03:29 PM
Neal's Avatar
Cool
HI!... Get yourself some REDLINE D4 synthetic tranny fluid. It is compatible with our transmissions. I've been running it in my tranny for 3 years now with NO problems.
