Transmission
Old Nov 7, 2002 | 07:48 AM
loosebruce's Avatar
Transmission
Hi. Have a '93 F-150 with 351 and auto trans W/overdrive. It has 240K on it but still runs great. Only thing is when cold tranny doesn't want to go in gear. Other than that its fine. Whats my tranny's problem . anyone know Thanks Bruce
Old Nov 7, 2002 | 09:45 AM
AB's Avatar
AB
Hi,
Do you know the vehicle history? Have the tranny fluid/filter ever been changed? Do you have enough fluid in the tarnny?
See, if the fluid was never changed that might be your problem. The tricky part is to how to change it… The tranny might start leaking after you change the fluid (there is a possibility) and you might end up replacing the whole thing…
I am using "might" all the times…
Alex.
