automatic transmission
2002 Screw 1100 miles, not sure which xmission I have.
Has anyone noticed or dealt with shudder when taking off from dead stop when in overdrive only? With overdrive off, do not notice it.
Re: automatic transmission
my '02 s-crew has a thunk/clunk upon stopping or taking off from a stop...but it doesn't matter if the overdrive is on/off.
Pete
Hey, I have the same shudder too. Last for only the first 1/2 second. I had chalked it up to axle wrap causing a slight bind in the u-joints under hard launch. I had decided not to worry about it unless it was still there after adding traction bars to control the axle wind-up.
I've never checked to see if it is the same in or out of OD, I'll do so today.
Let us all know if you find a trans problem.
Not that I discount your observation, but from rest the transmission operates EXACTLY the same with the overdrive enabled or disabled. The only differences are when coasting, and with the overdrive disabled you don't shift to fourth gear.
