Should T/C be drained w/ every ATF change?
Old Aug 2, 2002 | 09:01 AM
gtrjim's Avatar
Question Should T/C be drained w/ every ATF change?
The manuals aren't clear on this? What's your experience: do you drain the torque converter fluid every time you do tranny fluid/filter change?
Old Aug 2, 2002 | 09:40 AM
AjRagno's Avatar
The manuals don't even tell you how to drain the torque converter
The answer is yes, always drain the torque converter. The transmission only holds 5 qts. The rest is in the converter and the lines.
Old Aug 2, 2002 | 10:58 AM
gtrjim's Avatar
Thanks, AjRagno!
