View Full Version : Engine
  1. Hurricane V8
  2. Speed ctrl?
  3. 1990 Ford F-150 Problem
  4. Gas mileage?
  5. Guages constantly sweeping...
  6. How do you know if the EGR is working?
  7. Spark Plugs?
  8. Code P0302
  9. 95f150 won't start... check engine stopping
  10. next service
  11. Trufilter
  12. pinging rattling knocking
  13. Port and polish
  14. Who is in the 200,000 mile club? (321,800 kilometers)
  15. has power, won't start
  16. Code Scanner!!!
  17. Spark plug removal
  18. trouble code p1134
  19. Questions on a Turbonater?
  20. Accel or MSD
  21. white substance in oil cap
  22. Engine Swap
  23. help
  24. 93 f-150
  25. Engine Replacement
  26. hesitation
  27. engine light
  28. Phew... That was close!
  29. no compression
  30. Help on code P1131
  31. F-150 5.4 Liter No Start/Hard Start
  32. how much can it take?
  33. 93 f-150 question
  34. i6 and 302
  35. core plugs............question...
  36. New Mobil Motor Oil
  37. changing front o2 sensors
  38. idle problems
  39. Who hates trouble codes????
  40. Spark Plugs
  41. Is the Filtermag worth it?
  42. went mudding and now i got a ticking sound
  43. 1999 v10 vs. newer models
  44. 2 Problems! Temp. Gauge, Engine Light
  45. spark plug porcelin shattering off
  46. Motorcraft Oil
  47. No start F150 and a good chevy story.
  48. How do I clean the MAF sensor?
  49. o2
  50. Alternator?
  51. Loud Power Steering Pump???
  52. heads
  53. airbag light
  54. disassemble the column / '89 XLT
  55. How to bypass the PATS ???
  56. NGK Spark Plugs
  57. tune-up what is recomended
  58. 1991 5.0L To 5.8L Engine Swap
  59. Question on mass airflow
  60. o2 sensors where?
  61. Engine Surge/ Rev @ Stop Light
  62. Engine Light
  63. hypertech programmer III
  64. Governing top-speed down.
  65. performance programmer
  66. 4.6L V-8 Question...
  67. modular performance crate engines
  68. corrosion on new plug wire
  69. engine chugs at 2000 rpm?
  70. Starter wiring diagram??
  71. Did I make a mistake buying the '05 F-150?
  72. 5.4 Idle Speed Fix?
  73. Should I change all the fluids soon?
  74. new and need some help snow is coming and truck is broke
  75. Better gas mileage
  76. 2004 F150 goes full throttle at stop
  77. Idle
  78. random hose?
  79. Rockinrandy------>
  80. leaking head gasket or valve cover? should i trust them?
  81. Champion Irridium sparkplugs any good?
  82. 75mm Throttle Body
  83. 5.4 Engine Idle speed
  84. 4.6 by the years
  85. couple diff questions
  86. question about freeze plugs
  87. buzzing sound idler pulley??
  88. Radiator Stop Leak?
  89. Needing some help
  90. Timing an 5.4 F150 Eng
  91. Junkyard engine options - 89 F-150 5.0
  92. rattling noise...need help
  93. water getting on spark plugs
  94. Serpentine belt on `99 Expedition
  95. Did mobil stop making 0w-20?
  96. freeze plugs
  97. Radiator Flush problems
  98. Oil
  99. Fuel Pumps
  100. Starter problems...
  101. Misfire cylinder #6 PO306 4.2L
  102. Cluless Ford Parts & Service Dept on Spark Plug Tourque
  103. E150 Spark Plug Acces
  104. won"t idle
  105. New IAC makes engine idle too high...
  106. High mileage 5.4's with no spark plug problems?
  107. improvements for stock in line 6?
  108. Gas Pedal "Popping"
  109. throttle body question
  110. poor MPG, power loss in low rpms
  111. Porting and Polishing?
  112. blue smoke....
  113. Starter "melted"?
  114. Engine Problems, ignition system
  115. can't start engine / '89 XLT
  116. Under drive pulleys
  117. P1408 & P1000 Codes
  118. Fram - the lovely orange filter
  119. PCV Vaulve Replacement
  120. 1995 ford f50 fuel pressure test
  121. Oil change at 145,000 miles.
  122. 1995 ford 150 fuel/electrical dual tank problem
  123. engine swap
  124. Right Side Head Gasket and oil leak
  125. Name that mystery part!
  126. 2005 5.4 3v knocking
  127. Moisture in the engine
  128. engine cuts out
  129. no power from motor
  130. Cleaning Throttle Body
  131. Lowdown On The New Mobil Products?
  132. PCV Valve
  133. 1995 ford f150
  134. mine goes strong...
  135. 5.4L engine rattle
  136. 6 mpg
  137. brand of gas affect mpg????
  138. Interesting problem in 2001 5.4
  139. Question - need help!!
  140. need help with 1994 f-150
  141. 302 vs. 351
  142. need more power
  143. ping, ping, ping ,
  144. 4.2l misses during acceleration
  145. pulling out a 5.4 motor
  146. Possible to Swap 4.6L with 5.4L?
  147. startup tapping
  148. loud tapping noise
  149. Wierd Problems (long)
  150. 98' 4.6 Windsor ticking at start
  151. Strange "whirring noise"
  152. Electrical gremlin or engine?
  153. 1986 F150 engine swap
  154. Chime Update...
  155. Swepco?
  156. do 2003's have the plug blowout problem?
  157. rebuilding 302
  158. missfire problem for over a year goes unsolved
  159. 302 questions
  160. coolant leak of unknown origin
  161. f150,5.4 throwing spark plugs
  162. 30K Service
  163. rear end whine?
  164. A Flutter
  165. 5.4 Block issues 1997 E 350
  166. Rebuilt motors
  167. Cylinder/Injector/ Coil misfire
  168. who is running GT-40P heads and what headers?
  169. 97 F150 XLT 4x4: I had my engine rebuilt...and then some!
  170. P 1401 code…Help
  171. Vacuum Line Help...
  172. motor pinging
  173. my f250 91 5.8 can't pull the revs
  174. 98 f150 4wd is mindblown
  175. bucking f150
  176. 4.6L 3V from autoweek
  177. Windsor vs. Romeo engines???
  178. hard time shifting out of overdrive
  179. Flashing Check Engine
  180. modular engines
  181. rough 5.0 idle
  182. Where do you buy your MC 5W-20 oil ?
  183. When gas mileage is this bad
  184. Trading Her In
  185. amsoil Ow30 or 5w20
  186. Remote oil filter
  187. throttle body
  188. oil filter ADBV's
  189. where to get radiator
  190. Fan Clutches
  191. tries to stall when i tap the gas
  192. How to set timing 4.6L
  193. check engine light after new muffler
  194. Check engine light
  195. 5.4L engine
  196. 351w? or stang?
  197. Million miles on an '86!
  198. EGR valve bypass
  199. runs horrible and flashing Overdrive light
  200. Going Around The PCV Valve
  201. What tells you it's the Fuel Pump?
  202. Pulled a couple of codes on a 4.2L
  203. Front Rotors (4x4)
  204. Slow Start-up
  205. Oil Consumption
  206. My Ford Owner Website
  207. cold start starving for fuel?
  208. Few questions...
  209. Question to Neal
  210. Snorkels
  211. Po401
  212. Synthectic Oil Yes or No???
  213. identifying my 5.4s cylinder numbers
  214. How to change spark plugs
  215. Another MPG post
  216. '99 5.4 Oil Leak again
  217. Tapping @ Start up
  218. Best oil options for new(ish) 150?
  219. 95 302 Question
  220. Corroded Intake Manifolds - White Smoke coming from exahust
  221. Squeal - squeak at cold startup
  222. When to upgrade Injectors
  223. Bigger Radiator fit?
  224. triton blocks,do they crack easy on impact?
  225. PO125 again!
  226. need help with code 9202
  227. What else?
  228. Engine Performance
  229. Last Ford for me
  230. Oil change interval?
  231. Re Hey OE812
  232. help please!!!!! CEL!
  233. aftermarket tachometer install HELP!
  234. Broken water-pump bolts!
  235. Triton 5.4 Blown Plug + Ford ESP PITA === Should I sue?
  236. Where is cylinder head temp sensor?
  237. coolant flush
  238. 4.2L engine questions
  239. Change 5.4 MAF to Lightning MAF
  240. Oil filter relocation
  241. 1997 F150 5.4L seems like it is searching for idle.
  242. head gasket or not?
  243. Leaking Radiator
  244. oil in the spark plugs
  245. Another 4.6 misifiring
  246. acetone?
  247. cylinder heads
  248. To oil or not to oil K + N
  249. Marbles in the engine
  250. mac performance
