...found on road dead
Old Dec 18, 2007 | 05:47 PM
co89f150's Avatar
Help, my 1998 f150 5.4 4x4 stalled while driving and will not restart. Engine cranks normal but won't run. Won't start when given a shot of carb cleaner [the kind you can drive out of the woods on when your fuel pump dies...don't ask how i know] All fuses and relays checked good and the fuel pump runs when you turn the key[also full tank]. A friend told me to stick a crank sensor in it but that just lightened my wallet. [I have .04-.05 volts at crank sensor, mass air flow,and camsensor with the key on] Any Ideas?
Edit: also no codes or check engine light
Old Dec 18, 2007 | 05:51 PM
Klitch's Avatar
your cops actually firing?
Old Dec 18, 2007 | 05:56 PM
co89f150's Avatar
no spark with hei tester.
Old Dec 18, 2007 | 05:57 PM
R1Jester's Avatar
Fuel filter clogged? Pressure on the rails?
Old Dec 18, 2007 | 06:07 PM
TECHDOC's Avatar
Edit: also no codes or check engine light[/QUOTE]
The check engine light doesn't come on with the key on?
Old Dec 18, 2007 | 06:13 PM
jbrew's Avatar
+1 on the fuel filter and checking to see if your Check Engine Light works in the run position..
Keep in mind you only have 6 seconds to start or it's not going to - PCM shuts the rail down after 6 seconds..
Old Dec 18, 2007 | 06:31 PM
co89f150's Avatar
I don't see a check engine light w/key on or cranking.
Old Dec 18, 2007 | 06:47 PM
LastSplash's Avatar
Sounds like the power supply to the ECM is blown or the ECM has died.
Old Dec 18, 2007 | 07:13 PM
jbrew's Avatar
You sure you checked ALL the fuses? The two 175's checked out? You check the inirtia reset ?
Old Dec 18, 2007 | 08:21 PM
co89f150's Avatar
Yup, key on power on each side of each fuse [under dash and power distribution box] checked inertia switch not popped. wiggled ecm plugs no change. If the 175's are the big in line fuses on the firewall than i've been there too. Also seems that the eec power relay,horn,fuel pump relays are all the exact same part number[in power distribution box] so i switched them all around to no result[they also all work in the horn relay slot i.e. the horn beeps]. Thank you all for your continued help
Old Dec 18, 2007 | 08:33 PM
Tumba's Avatar
did you also check the mini fuse box directly behind the main distribution box under the hood
Old Dec 18, 2007 | 09:02 PM
co89f150's Avatar
While checking all the fuses again i found my problem. bad connection in fuse box under/in dash. while checking fuses on the right side of panel i heard a relay click but i still had a no start until i pushed on the fuses then the check engine light came on [had key in run position] when i stop pushing on fuses truck stalls. I guess i should work in the dark when the neighbors are quiet more often. thanks for all the help guys!
Old Dec 18, 2007 | 09:48 PM
jbrew's Avatar
Huh!! Let us know where the short is if you find it . I wanna know anyway , I have the same truck
Old Dec 18, 2007 | 10:03 PM
Pheonixx's Avatar
tap the relay with a screwdriver while someone turns the key, if the truck starts then your relay is bad.
(you can test a fuel pump relay same way, thats how i know that)
Old Dec 18, 2007 | 10:05 PM
co89f150's Avatar
Found it. fuse/location #30 in the dash panel 30amp radio nosie capacitor, ignition coil, PCM power diode. Fuse is loose in its hole. looks like someone has been in there before and their fix was to bend the fuse legs to make contact again. I'm going to make a more perminant fix!
