250 km on a full tank !!
Yep that's right
Hi everyone,
I used the search button but no luck
Here's my problem, I have a 1997 F250 Lariat, 300.000 km, that suddenly, burn gas like it is free. I went to the dealer, he took my $300 and change the air filter (apparently it wasn't the good model
). I suggest a O2 sensor but they said that 'no code, no need to change'; fuel pressure is good, injectors are good.
That was 3 days ago...I did 80 km and burn 1/4 of the tank already...
The truck seems running ok, no strange noise, smoke, loss of power... everything seems fine beside $100 in gas for 250 km
any idea ?
thanks guys !
Hi everyone,
). I suggest a O2 sensor but they said that 'no code, no need to change'; fuel pressure is good, injectors are good.That was 3 days ago...I did 80 km and burn 1/4 of the tank already...
any idea ?
thanks guys !
Originally Posted by Z-Hunter
Yep that's right
Hi everyone,
any idea ?
thanks guys !
Hi everyone,
any idea ?
thanks guys !
But it sounds like an emissions issue... like an o2 sensor... once it goes, it will fire a code. For now, you'd be throwing parts into it.
If you haven't changed your front 02's than i would recommend doing it. that is probably the cause. there wouldn't be a code if the sensor figures it is working properly. Change them you will be glad you did.
I believe there are 4 of them. I would not have any children or any people that are offended by foul language around you while you are replacing the upstream sensor on the pasenger side. After I replaced mine last summer I came to the conclusion that whoever put it in that spot at that angle deserves a kick in the crotch.
BTW when my O2 sensor died my check engine light came on and there was a code for the sensor so yours may not be bad, I would recomend that you have your PCM scanned for pending codes, if a sensor is working intermittently it will set a code but not light the check engine light.
Just replace the first 2 that are before the cats. the ones after the cats are there just to tell you that the cats are working properly. The first ones get lazy. They may not fail totally and throw a code but they will wear out and need to be changed. I would recommend changing your o2 sensors every time you change your plugs.
Originally Posted by Gotts2BMe
..... I would recommend changing your o2 sensors every time you change your plugs.
Originally Posted by olgzr
Do you recommend getting them at a Ford dealer or aftermarket? My truck has 140K miles and I'm still on the original O2 sensors.
hey guys,
i'm in trouble again !! I changed the O2 sensor and my problem seemed fixed for a tank of gas (+400 km) but I'm back with my 200km a tank
On top of that the engine misfire after a cold night outside
and I 've now a check engine light !
I don't know if these two problems are connected but I start to worry here.
Any idea of what to check ? my mechanic (as well as Ford dealer) sounds lost
Thanks for your help !
and I 've now a check engine light !I don't know if these two problems are connected but I start to worry here.
If you have a check engine light then you have a code. I would suggest going by any Autozone and have them put a scanner on it. It's a free service. I would also be looking at the Cats to be plugged. If you haven't changed them, it's time. Next time you have an O2 sensor you think is going bad, buy a pair of cheaters first. If the issue doesn't change, then you just saved a bunch of money. And if one goes bad, just plug in the cheater until you can fix it. If you haven't changed plugs, wires, and coils, in the last 50,000 miles, now is a good time. But pulling the code first is where you need to start.
