Will not idle(sometimes)
Old Dec 18, 2007 | 12:10 PM
Captain_Nemo's Avatar
Arrow Will not idle(sometimes)
99 4.6L Sometimes when I start the truck it will not idle until it warms a little then its fine. Today same thing but after fully warming up it barely idled and surged a little, no engine codes. I turned the engine off and pushed the petal to the floor and turned the key on, next I let off the petal and started the truck. It barely idled for just a brief second and then it idled like normal. Maybe a bad throttle position sensor? Ideas anyone?
Old Dec 18, 2007 | 12:26 PM
R1Jester's Avatar
Do a search, but it could be a few different things. Vacuum leak, bad IAC,...those are some things you can check first. It's a very common problem, but I have yet to find a common answer.....
Old Dec 18, 2007 | 06:13 PM
Toyz's Avatar
Clean your IAC
http://www.fordf150.net/forums/viewt...er=asc&start=0
Old Dec 18, 2007 | 06:26 PM
jbrew's Avatar
Classic IAC problem
It's better when warm because your 02's are assisting at that point. Cold , there NO help..
