Loud Squeal at start up
Have 2004 F150 xlt supercrew 4x4 problem is loud high pitched squeal in engine bay towards the front. Could this be waterpump going out? I have no heating or cooling problems. Belt also looks fine. Alternator is working fine. This occurs mainly at start up and acceleration. After a short drive it quiets down quite a bit. Last night it was the wost it has been. Weather was 50 F and rainy. The pitch of the squeal changed a little when my wife turned the dash heater ***** from vent to defrost. It was real loud like a hay baler. If any one can help with this diagnosis I would appreciate it!
Vacuum leaks can be quite noisy...my old truck with the 300 got a leak in one of the HVAC lines and it whistled loudly enough to hear over the radio while driving.
Have the motor idling, pop the hood, and get a length of tubing (doesn't matter what kind, just small enough so you can place it right next to your ear. Hold the other end of the tube and wave it near possible sources. A/C, alt, idler, tensioner. If one is making noise you'll know it.
If it's a pulley get a can of wd-40 and spritz it on the suspect one. If it stops for a few seconds and then gradually returns you've got a bad bearing.
Get a helper to turn the a/c on and off while you listen. If the squeal starts/stops accordingly then you've got your culprit. If it squeals all the time but comes from the a/c, the clutch is going.
Not the belt or vent ****
Originally Posted by glc
You sure it's not just a worn belt screaming?
