- Tranny Problems??
- what shift kit fits 4r100 tranny
- Please Help
- What transmission do I have?
- New Fluid, but Old Filter
- Grind???
- Transgo?
- Heavy clutch effort after long drives???
- F250
- Trans clunk during quick stop
- 2001 S'Crew tranny & seat probs
- Changing fluids
- mercon V change interval...
- Trans sticking in gear while in cruise?
- Shift knob
- Jerking/kicking when coming to a complete stop..
- Clunk sound when shifted into reverse
- 99 Exp-Replaced torq conv at 42k
- leaking-pinion seal
- clunk during turn
- How do I empty my torque converter?
- Transmission Leaking?
- Decision help?
- Aod
- Manual Trannie Upgrades
- shifting problems
- problems going into reverse...
- 4R70W service manual?
- Tranny Temp Gauge installed
- sliping
- Working on Short-Throw shifter
- tranny swap
- Shifting Problem
- Automatic tranny lost Overdrive
- Play in driveshaft where it exits tranny?
- Strange Thing happened
- When should you change fluid in manual trans???
- help me go faster
- fluid chant
- Now What's Going To Blow...??!!
- Tranny Probs.
- Fluid Amount?
- Fluid!
- rear end posi lube question
- Did i blow up the tranny?
- Bad TQ Converters in new 150's????
- anyone install a Buaman shift kit in a 2002 4R70 yet?
- slipping?
- Are the E40D any good?????????
- Calling Factory Tech: Problem, not sure how to explain it
- Can anyone recommend
- hhhh
- Are autos stronger than manuals?
- Baumann Shift Settings
- I did the Tranny fluid change
- Redline?
- non-limited vs limited slip xmission
- New Tranny
- New truck and I have questions...
- something amiss???
- E4od 4r100 Rebuild Questions
- hard to get into 3rd gear
- slipping
- Trans info needed
- Shifting Delays
- trans in a '92, F250, 300 six?????????
- Manual Transmission Shuddering
- thumping under truck
- anyone tried this?
- Pressure loss on clucth pedal
- What are the rear end codes for 99 f150?
- Shift RPM Question
- Slight vibration @uphill startup
- Rear seal fallout
- 96 clutch pedal slip
- stutter/miss after OD TC lockup
- 4R70W Fluid Capacity???
- What Transmition Do I Have??
- Tranny Shudder?
- Fittings on Transmission Cooler
- New (Ford reman)Tranny for My Expy
- What brand of MECRON V fluid???
- TC draining ?'s
- nyone installed a Hayden Rapid-Cool transmission cooler?
- Transgo
- Best Tranny Cooler...Recomendations???
- Tranny service questions
- E40D vs Mazda M5R2-C
- Transmission Won't Shift
- TC shudder back after fluid change
- Torque Converter
- Oil Cooler
- 4R70W pan
- hard shifts with chip
- $1,000 Transmission service at 49K Miles - OUCH!
- clunking noise
- Incorrect Gears?
- Baumann Install Experience (long)
- buying trans-go???
- 187,00 on tranny
- Changing transmission fluid
- Towing and tranny coolers
- Clutch Replacement...
- tranny?
- ? on which tranny and a noise in it
- Transgo Help Line
- T-5
- Ever seen a tree hit a Cheby??
- Most miles with TRANSGO?
- Anyone have experience with the Jet Power Shift Kit?
- Transmission Problem?
- need a tranny?
- aftermarket manual shifter?
- Tranny questions
- gears for a 4.6 auto?
- Changing Fluids
- Found mushroom in tranny pan
- Quick question
- 4R70W transmission pans?
- Vibration in rear end
- Tranny Flushing....anyone tried this???
- 6-spd kit for Lightning?
- Two or three second delay from R to D
- Changing fluid after 100k miles
- TransGo Shift Kit Install
- What Transmission
- Howling Drivetrian
- Leaking Transmission
- Transmission cooler standard equipment on a 1998 F150 XLT?
- 97 F-250LD Clutch question
- Tranny Question (Normal or Not)
- 4r70w fluid interval changes...
- Towing
- Opinions on upgrading tranny cooler?
- Is ProLine and Mercon the same thing?
- Friction modifier ??
- 4R70W transmission loss of overdrive
- Neal (Guru), Baumann
- trans id
- Keeping up with a Rice UV
- Trans acting weird need help...
- What's the difference in all these Trannys?
- d**n shuddering 4r70w..@^$%#
- Shift kit fially in !
- VIbration at 60mph
- F-150 Towing Problems
- Shuttering E4OD 1993 ????
- When to change gears??
- Ok, where is the code for the tranny on the doorjamb?
- Shift Kit VS Reprogramming?
- Hard Downshift Question
- Shift Kit For V6?
- Question on 97 F350 Tranny
- Tranny Temp Gauge Question
- Anyone here know much about mustang T-5's?
- 4R70W service and upgrades
- Stock Gearing and Trans. cooler question
- MerconV vs. Dextorn II?
- speedo fix on 99 F150
- How much should I bring?
- What Tranny Fluid? Who is Right?
- strange noise
- What gear?
- Tranny shifting hard into 2nd/ Please Help!
- Synthetic yes...but what kind?
- E40D to C6 swap???
- A rookie 4X4 question??
- tranny slipping ????
- Over Drive On/Off?
- 3:73 or 4:10's?
- Trans fluid change. Which fluid should I use??
- Thanks AjRagno
- Opinions on shift kits
- up hill
- In-line filter for 4R70W
- 97-98 speedo correction gear
- problem or not?
- AjRagno a couple of ????
- Auto Transmition dead at 2500 miles!
- Tranny Fluid Change Questions
- Manual fluid change and synthetics?
- finding out which transmission I have
- overdrive off around town??
- Tranny crapped around 112mph!!!
- SD 4by auto trans will not shift HELP I am on vacation !!!!!
- machanic question on 30k tranny flush
- Bad 'whirring' sound from around Converter ?
- 2nd time my trans took a dump on me........
- 4r70w transgo install
- Funny noise when giving gas to go up a hill
- ? for 2kExpi
- Will this converter work???
- weird problem
- O/D on off switch???
- shifting into 5th
- Tranny Type
- tranny shudder.....any one else with this problem?
- Towing "properly"
- FYI,Trans Fluid change Done
- Dealer forget to tighten my tailshaft...
- Tranny Gone-- 58,000 miles
- Replacing manual with automatic transmission
- 4X4 Transmisson Question
- 4X4 trouble...it won't catch....
- Switching to Amsoil Synthetic Trans Fluid
- Factory_Tech Question
- Transmission fluid change
- Trans-Go and what else?
- those with the 5 speed i need some help
- Mercon V info.
- Scary!
- transgo 4r70w question
- Has anyone experienced this....
- Do I have TC shudder?
- transmission model
- T-Handle
- Vibration
- 3-2 Downshift Click
- Trannie sucks
- Castrol 5W-20!
- F250 HD 6psd in a F150?
- Part time 4-wheel drive
- five speed problems
- transmission slip?
- What exactly is a shift kit...?
- tranny fluid
- Squeaky (sp) clutch..?
- Transmission
- Better Shifting
- shifter for 2001 5spd trans
- My experience w/ the mazda 5spd
- B+M ShiftPlus?
- Transmission fluid change from dealer
- Transfer case oil change easy --cheap
- shifter kit running 35s
- 4R70W 1-2 shift clunk
- rear end question
- Flywheel for a C-6
- Got stuck.. Need Info..
- clutch return spring
- Newby Dumb Questions...
- What is the most recommended Mercon V?
- Do you have this?
- transfer case fluid?
- leaking clutch master cylinder?
- Beefing Up the Manual Trannie
- transmission damage, low clutch fluid?
- torque converter drain/refill
- Ar ethe transmissions the same for the 4.6 and the 5.4
- manual tran. fluid change???
