Guide to Tranny Fluid Swap?
Old Oct 29, 2005 | 09:03 AM
HaulMyGrandPrix's Avatar
Can anybody point me to a guide for a tranny fluid swap on a 2001 supercrew 5.4L auto?
Old Oct 29, 2005 | 10:36 AM
adrianspeeder's Avatar
Howdy and welcome! What tranny do you have first of all. You can determine this by the door jam sticker code under TRANS.
The 4R100 is code E
The 4R70w is code U.
Adrianspeeder
Old Oct 29, 2005 | 02:31 PM
Bought the truck used, and there is no sticker on the door.
There are 14 bolts in the tranny pan if that helps and a big letter S on the pan. There is a hump in the middle.
Does that help?
Old Oct 29, 2005 | 03:16 PM
fordninja's Avatar
sounds like a 4r70w which takes mercon V in your year.
Old Oct 29, 2005 | 04:14 PM
casey_1's Avatar
Here is how I change mine:
http://www.ford-trucks.com/article/i...nsmission.html
Old Oct 29, 2005 | 04:20 PM
Sticker is on the door jam...
14 bolts however is the 4R70w. Use that flushing procedure and then be sure to use MERCON V!!!
Adrianspeeder
Old Oct 30, 2005 | 11:16 AM
98Navi's Avatar
Although that procedure seems to be throurough, there are better and easier ways to do it. We use whats called a T-Tech transmission flush machine. It hooks to the cooler lines at the radiator, and flushes 99% of the fluid, whereas when you do it you'll only get the pan, and if you choose to do it the TQ converter. That leaves whats in the cooler lines and sides of hte radiator as old, so you'd get about 85%
It usually cost different amounts at different shops. I charge 89.95 for it, ford gets like 149.95 around here.
Old Oct 30, 2005 | 03:40 PM
ViperGrendal's Avatar
This is what I have done. It's 109.00 at Tires Plus. I don't trust tranny shops any more. I'm sure there's cheaper places, but I can at least trust these guys aren't gonna F with nothin since they don't do reapirs on tranny's. I got F'd with the time before and got screwed outa $2500 at a tranny place (All Transmission World).
Old Oct 31, 2005 | 08:59 AM
casey_1's Avatar
If you follow the procedure I listed above you will change the fluid exactly like the T-Tech machine does. The only difference is that in this procedure you have to stop the engine and add fluid. The T-Tech adds it while the engine is running.
The end result for both is that at least 95% of the fluid is changed, and if you do it yourself you spend less $$.
Old Oct 31, 2005 | 09:35 AM
dirtyd0g's Avatar
It's all a waste of time if you don't change the filter. Personally I drill the converters and install a drain plug in them, but thats what I do.
Alan
Old Oct 31, 2005 | 01:13 PM
casey_1's Avatar
The procedure I referenced has a step to change the filter.
Old Oct 31, 2005 | 01:29 PM
98Navi's Avatar
The engine running flush will flush out the filter quite well also. The filters on those things don't get that clogged. The only reason I even bother changing filters in tranny's anymore is if they came from a junkyard and have been sitting, which would drop alot of contaminents in the filter. I mean, it doens't hurt to change it, I just changed mine on the navi, but only because its getting a more severe beating from the blower.
