Manual Tranny, plug washer
Old Nov 2, 2005 | 12:49 AM
TheToolManCDX's Avatar
Exclamation Manual Tranny, plug washer
I changed my Transmission fluid tonight and after I got done I realized that there was a metal washer in the bottom of my oil pan. It is a 5 speed in a 1999 f-150, so there are only 2 plugs I took out. I dont know weather it came from the drain plug or the fill plug. Does any one remember which plug has a washer. Thanks for looking. John
Old Nov 2, 2005 | 08:04 AM
bianconi's Avatar
tranny plug
wow, I have 97 5 speed, and I didn't remember a washer on either one. That's not much help, but does it leak??
Old Nov 2, 2005 | 12:29 PM
adrianspeeder's Avatar
Shoot, I cant remember actually and I have two M5ODs and do regular fluid changes. I wanna say no, but will look the next time.
On my 92...
Adrianspeeder
Old Nov 2, 2005 | 01:15 PM
mradclif's Avatar
I've done this many times on the M5OD. Both drain and fill plugs have the soft aluminum, one-time-use crush washer.
A 99 M5OD will soon start leaking tran. fluid out of the three shift rail plugs (covers) on the top rear of the transmission. Keep an eye on your tranny for leaks and look in your garage/driveway for red spots. Search this forum for M5OD and read my procedure on changing them.
Old Nov 2, 2005 | 01:22 PM
gaudenti's Avatar
"one-time-use"? I've always reused them. I guess as long as it doesn't leak, it's OK to reuse (or not use?) . . .
Old Nov 9, 2005 | 01:30 AM
there is a washer on each one. I took both of them off, to make sure. I did reuse the old ones, does not seem to be leaking now. Thanks for all the help.
