Binding In Reverse No 4x4 Low Light
Old Jan 5, 2006 | 09:19 PM
highways's Avatar
HELLO NEW TO THE F150... HAVE 05 KING RANCH 350 IS SHOP SO I BOUGHT A 05 150 4X4 THE 4X4 LOW LIGHT DOES NOT COME ON I SEE THAT THE LIGHT WORKS ON START UP.IN 4X4 LOW THE 4X4 HIGH LIGHT STAYS ON. I UNDERSTAND 4X4 ON PAVEMENT CAUSES BIND BUT IN REVERSE? THANKS IN ADVANCE.
Old Jan 6, 2006 | 09:40 AM
thedave's Avatar
4x4 in forward or reverse will bind while turning on dry paved roads, it's the nature of the beast. To go from 4 hi to 4 low you have to shift the transmission to neutral.
Old Jan 6, 2006 | 10:03 AM
adrianspeeder's Avatar
Because the front and rear axles are gonna turn at different speeds, and the transfer case on these trucks are locked, dry roads will cause a bind between the two axles. SO don't use 4x4 on dry pavement.
To go into or out of low range with an Electronic Shift On the Fly system, you need to be stopped, foot on brake, and in Neutral.
Welcome to the forums by the way! Just so you know, caps lock on the internet is considered yelling, and we can hear ya fine with out yelling.
Adrianspeeder
Old Jan 6, 2006 | 11:08 AM
highways's Avatar
thanks no caps
thanks got it
