View Full Version : V8 Engines
- EGR question.
- overdrive question?
- Best Synthetic Oil?
- Synthetic or Regular Oil?
- rough Idle
- Valve Cover Gasket
- Fuel filter replacment
- Cutting out
- oxygen sensor help ?
- Torque Curve Graph compare to Tahoe?
- Quality is Job What? Oil leaks
- Sparkplugs coming apart?
- Wants to start but won't
- 4.6ltr. idle noise
- In the market for a new scan tool
- bad skip
- Spark plug problems....again!!
- Single electric fan and heavy duty towing??
- A/C causing Iceberg
- Known issue w/ bad oil pres. sensor?
- 98 eclipse rs
- gt heads
- Who is trouble free and happy?
- Recommended Air Pressure
- Changing Air Filter
- Gas mileage??
- no code??
- Fuel Mileage
- Gear Lube or Tranny Fluid?
- AC draining on Oxygen sensor
- Smokes at start up (sometimes)
- Rough idle solved
- 4.9l inline 6
- '99 4.6L engine oil capacity?
- More Power
- Power Programmers
- what to do for a 100,000 mile service?
- 1997 5.4 w/E4OD
- MAF sensor cleaning
- fuel injection
- 4.2 L V6 0-60??
- wait a minute
- Break In For Rebuilt???
- Upgrading Fuel System
- Ever Used a Fuel Cooler?
- Low oil pressure cut-off switch
- Bigger Throttle Bodies?????
- Vids of your truck
- Sluggish 4.6L
- One Bad A$$ Supercrew!
- Need help with a fuel problem
- Oil Seepage
- 1st Triton....
- turbo
- Gears....
- Pusher or Puller?
- new engine noise on high mileage 4.6
- What's Hydrocracked Oil
- "SLOW" Motor
- missing when warm
- Does anyone race their F150?
- TPS question
- Calling jefflaws, EGR problem
- HELP - truck a no-start after driving fine today??
- plug wires mystery solved 4.6 mustang v.s. trucks
- egr system?
- Is this an error code?
- big engine prob
- Clicking noise in new 5.4
- Camshaft Position
- Whining Noise with warm engine....
- S'crew gas mileage?
- OBD/Scan Tools
- mid range miss
- Help don't know where to start!!!
- Dealer 1st
- Wierd Hissing Sound
- Timing question
- Electric fan kit for Sperduty?
- how much do these mods cost?
- engine stutter in 2001 5.4
- From Mobil 1 back to dino
- Timing
- Spark plug wires???
- Ford techs please
- Please Help Me
- Engine Emblems (ex.- 5.4L or 4.6L)
- Jl Intake Box
- anybody been through the head gasket leak problem?
- Where can i get Techron fuel treatment?
- Odometer information - how to get to the diag mode
- 5W20 oil
- This is cool
- 5.8 to 5.4... why?
- Camshaft swap?
- Flex-a-lite rocks!
- Over Head Cam Or Pushrod
- cobra heads
- What are some good mods?????
- Oil specs (lord, I really don 't want to start this again....)
- 5.4vsV10
- 99' 5.4 Stuttering, shuddering, missing, hestitating
- CMP Sensor Malfunction
- How to get TSB info????
- engine ping
- Ford to unveil new diesel motor and Excursion SUV
- oil pressure gauge
- Where are the plugs on my 5.4??!!
- Love my new truck
- code 311
- "Leak" search = 690 Engine topics?!?
- 4.6 vs 5.4
- Battery Dead After 2 weeks of sitting?
- 5.4 super crew Dead engine
- Glad I have the 5.4!!!!
- Time to Supercharge
- changing oil pan on 5.0
- 5.4L idling problem
- not shifting correctly
- engine is missing
- oil pressure switch
- GRRRRR.....JBA header won't line up!!!
- towing package parts
- V6 Needs More Power
- K&N Filter Question
- whining noise under acceleration
- Plugs lost their poop
- what happened to being built ford tough
- SEAFoam?? What and why?
- Anyone replace a waterpump on a 5.4?
- Are those CD shop manuals on ebay any good???
- Rough Idle, Motor Mounts?????
- idle problems
- Trailor Light Hook Ups
- 460ci engine won't start. Please help!!
- Anyone Replaced Their Own Fuel Filter?
- PI intake manifold
- Oil Filter Relocator kit
- Just bought a 1998 F-150, need help...
- 99 HP increase
- need some powaaa here!!!!!
- Thinking of pin striping my black s/c any ideas on color of stripe
- Heater Core Help???
- Mobil 1......Super syn vs Tri syn???
- engine swap
- Engine Help
- I Wanna Mac!
- Under Drive Pulleys
- which is the best...?
- Solving the rough idle problem!!!!
- top speed limiter
- New, and need some help
- ford replacement motor
- MAC intake
- 01 4.2 Leaky Head Gasket...info needed
- more HP on an 88 with a 302
- Dual 15 inch blades?
- Simple Green
- Brand new '02 4.6 turns over, then immediately dies ??
- Good 1/8 mile time....
- Pi Heads
- serpentin belt
- Need advise
- Hey "Home Skillet" ? for ya!
- Building a new 5.4 for power...
- Do all 5.4's sound like a diesel????
- Fuel brands, mileage, and engine cleaning...
- Anybody found a fix to this valve clatter problem?
- 0-60
- Got a new MAF today.
- How to tell if you have PI heads???
- "Intake Manifolds" are coated with oil
- Neal and other Modular motor guru's get in here!!
- 3 valves for the 5.4....
- Head Gasket TSB
- 5.0 L Water Pump R & R
- Any trouble with straight pipes?
- Valvoline Screwed My Thermostat Somehow Help!!!
- engine codes
- Interesting
- Which order should I do this in?
- Amazed at K&N filter...
- JET NON PERFORMANCE Module for my 1999 5.4 VERY Dissapointing!!
- goin from a 300 6 to a 400 v8???????
- Texas Emission Test
- Racing in the 5.4? Remove Spare?
- Stumped !
- Startup tapping, oil filters and so on.
- Disconnect fuel line from rail
- Newby Tow package retrofit HELP
- Air Filters
- I killed my truck - no longer starting
- Where to find Lightning Long block crate engine?
- Problem, not sure how to explain it...
- Gas/Fuel ABG vacuum line
- best mod
- Relieve pressure in fuel rail
- overheating '97 4.2 auto
- Noise when turning into a drive way
- Spark plug wire suggestions??
- How do you find out the "Inservice" date or the date your truck warranty started if y
- 97 F150 5.4
- 75 Mm T/b's
- Noise in 97F150 5.4 EGR valve
- Fixed- Buzzing under dash 97F150 5.4
- Engine knocking on startup - should I ignore it or make Ford fix it.
- Thoughts on CD-2 Engine Cleaner & Detailer
- Repair manuals for Superduty
- Where to get MAC Air intake?????????
- Vacuum noise when in drive and not accelarating
- Fossil to synthetic...Synthetic to fossil
- Oil TSB
- Low power at hot outside temps
- engine sensor mod?
- MAC fipk
- control box under bed?
- I have the lemon of all lemons...
- Goodbye and No Thanks!
- Poor 5.4l performance :(
- Ram air or open element?
- 1996 5.8L Ignition Problems - Fails to Run
- If you've used a "teflon" additive, don't use Amsoil oil?
- Adjustable FP regulator for 4.6
- What oli do you guys use?
- 1988 F150 Fuel Pump Problem
- MAC Intake Performance System
- How to check A/F ratio?
- Surge at idle?
- truck wont start
- K & N Breather Element
- Improving My F150
- '99 5.4 missing then quit?? HELP?
- 89' 460 ---Severe Knock & Ping Problem
- Fan Clutch question
- Idles very high
- My Baby Has Piston Slap!!!!
- Prepared
- F150 Problems
- Please tell me what to look for before i go for warranty work.
- P.O.S. Truck in shop for 5th time
- I smell antifreeze... plz help
- 93 Octane
- nitrous
- AC/Fan Problems
- intake kit ?
- Maintenance costs...
- Warranty Almost Out - What Problems Should I be Looking For?
- Idle Problems
