Gears....
Old Jun 5, 2002 | 10:27 PM
4X4PWR's Avatar
Gears....
How can I tell what gears I am running? Should there be a sticker somewhere that tells me? I imagine it should be somewhere...
Thanks in advance.
Old Jun 6, 2002 | 08:32 AM
98STXV8's Avatar
The sticker in the driver side door will tell you it will say 3.08 or 3.55
Old Jun 6, 2002 | 10:54 AM
douga49's Avatar
98STXV8,
I thought I'd look at the sticker as you suggested, but I can find no mention of the gears on it. What am I doing wrong?
Doug
Old Jun 6, 2002 | 12:07 PM
MitchF150's Avatar
Wink
It's there, but it's in code. Look for "Axle" and the code for it will be something like "H9" (3.55 Limited Slip) or "I9" (3.55 Open). I don't recall the others, but just take another look and post it and someone will be able to tell you what it is.
Old Jun 6, 2002 | 12:09 PM
George Kropp's Avatar
Gears
Unless someone removed it there should be a metal tag attached to one of the cover plate bolts on your rear differential. The last three numbers on the tag is your gear ratio. There is also a letter code on the door tag that tells you what gear set you have but I don't remember what they are. These codes have been posted before. You will have to search through the threads on this site. Good luck.
Old Jun 6, 2002 | 12:32 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Smile
Yep the tag on the diff. is the deciding factor. For example, if the gears were 3:55 limited slip, the tag would read,,,,3 L 55. If it's an open dif, it would read,,,,3 55. Good luck finding your ratio,,,,98
Gears
Hope this helps. Open the drivers door. inside the door there is a sitcker. Look on that sticker you will see a box labeled axle. here is what that code coresponds to for ford trucks
F-150:
19 – 3.55 Non-LS
18 – 3.08 Non-LS
H9 – 3.55 LS
B6 – 3.73 LS
Old Jun 6, 2002 | 12:37 PM
douga49's Avatar
Perfect
Thanks,mine says H9. Where did you find out what those codes mean?
Doug
Old Jun 6, 2002 | 10:39 PM
Gears
I was on the F-150 world web sight and ran accross this list. I knew I had seen it before but couldn't remember where. Both F-150 online and F-150 world offer tons of info about our trucks. I browse them both almost daily.
Old Jun 7, 2002 | 10:11 PM
4X4PWR's Avatar
Thanks!
Looks like I have a 355 Limited Slip. I also checked the weight of my truck.... holy hell... 6,032lbs. Im driving a tank. I think its time for me to trade in my truck for the new Super Charged Harley. =)
Old Jun 8, 2002 | 11:14 AM
4x4pwr
Seems like there are a lot of F-150 owners out there that want a fast truck with outstanding gas milage. The only way that is going to happen it to transform the veh. into something it was not designed for. I have to admit I also looked for more power and better performance. Let's face it these are heavy vehicles. Especially if it is a 4by. I put a superchip and 4.10's ETC to help getting off the line and it helped especially when I have had my Jeep in tow (Truck not used for rock crawling). Sure likes to fly now but does not pass too many gas pumps. Anyone out there find the answer let us know short of buying something smaller or brand new.
