AC/Fan Problems
Old May 6, 2002 | 09:40 PM
Dan97's Avatar
AC/Fan Problems
Got a 97 X-Cab w/ the 5.4L...was out at FFW this weekend in down here in Houston, TX. Was getting ready to leave on Sunday, fired up the truck, started the AC, put it to high...about 5 minutes later, and small shudder, then bam, no ac. Restart engine only to find out that the fan isn't even blowing. Nothing is working AC/Fan related, the defroster won't even work. Can't seem to find out what the problem is. Any and all suggestions would be appreciated.. Thanks in advance.
Old May 6, 2002 | 09:52 PM
TexfordD's Avatar
wham bam no a/c man
1) check fuses 2) check to see if clutch is turning with belt 3)check freon pressure 4) check vacume acuation hoses for air dam doors 5) take to pro
