Heater Core Help???
Old May 21, 2002 | 07:48 AM
5.4lariat's Avatar
Talking Heater Core Help???
This is for anyone who has replaced the heater core in their truck, what is done after the glove box is removed??? Thanks for the help anyone!! I have to take the heater hose pinch off tool back tony buddys shop before too long, and damn that was the cheapest thing I ever bought from ford...29.95, +tax, having a friend at the parts counter really pays off!!
Thanks to whoever can help..
5.4
Old May 21, 2002 | 12:15 PM
JMC's Avatar
JMC
25 Year Member
Are you replacing the heater core? Do you have a manual or you guessing at what to do? I replaced mine and it is not something I would do with out the manual.
Regards
Jean Marc Chartier
Old May 21, 2002 | 12:31 PM
kidtriton's Avatar
You missed a step, before you take the glove compartment out, you need to take the whole dash out. Then, recover the AC refrig. and take the evaporator case out, then you can open the case and get to the core.
Old May 21, 2002 | 05:48 PM
JMC's Avatar
JMC
25 Year Member
5.4lariat,
I have done it on my 00 F-150. It is a pain in the *** to do. it is not difficult just tedious. BTW you don't have to evacuate the AC on the 97-01 F-150s. RTFM
Jean Marc Chartier
Old May 21, 2002 | 09:06 PM
kidtriton's Avatar
OH yea, you dont have to evac. the AC
Disconnect the battery. For additional information, refer to Section 414-01.
Drain the cooling system. For additional information, refer to Section 303-03A.
Remove the instrument panel. For additional information, refer to Section 501-12.
Compress the holding tabs and disconnect the heater water hoses (18472) at the heater core (18476).
Remove the A/C plenum demister adapter (19E662).
Remove the screw.
Remove the A/C plenum demister adapter.
Disconnect the vacuum line.
Remove the heater core bracket.
Remove the screws.
Remove the bracket.
Remove the plenum chamber top.
Remove the 13 screws.
Remove the blend door assembly from the case.
Remove the heater core.
Old May 21, 2002 | 10:10 PM
NINETYSEVEN's Avatar
Angry
5.4lariat
i replaced my heater core last year on my 97.
let me tell you it is very tedious!!!
you will have to take your time.the entire dash does have to be removed.it comes out in different layers.be prepared to take a lot of screws out.most of all be carefull of the removal of airbag.
myself i did not have to evac. the system.
it took me about 9 hard at it hours to do this job and i am not a mechanic.
good luck i hope this helps.
Old May 22, 2002 | 01:09 AM
5.4lariat's Avatar
Talking Well, damn...I dont need the manual!!
Well thanks to all....I do have a Chiltons and Haynes manual, I did the core on my 88' Bronco II, It was a pain....this sound like a nightmare...well hopefully I will have some spare time real soon the change it out, has anyone ever put a ball valve on the two hoses, cause you dont need heat in the summer, especially Texas...I heard that the core not circulating hot fluids decreases the whole compartment temp and the evaprator (cooling coil) runs aboout 6 degrees cooler, Id love some cooler A/C and less ware on the heater core...Will shutting off the fluid flow hurt the water pump or anything else??
Well thanks for all the responses, coming home from a long day and having all the answers there is nice...thanks again guys!!
5.4
Old May 22, 2002 | 01:47 AM
JMC's Avatar
JMC
25 Year Member
When you get around to changing it keep the pipes from the old core and have them welded together. In the summer when you don't want heat just disconnect the heater core and connect the hoses to the two pipe ends.
BTW I didn't have the disconnect tool so When I got the plenum lid off I cut the pipes off the core and removed it that way. I wouls also recommend getting new connectors and O rings for the heater hose to core connections.
Regards
Jean Marc Chartier
