View Full Version : Engine
  1. Check engine light - How to clear?
  2. distributor bolt size
  3. OOOPS! Two quarts low!
  4. 302 Engine Questions
  5. Drive Belt replacement question
  6. Tensioner pulley moves at idle, smog pulley wobbles?
  7. Question-P1000 code
  8. Thinking of Buying a '98 4x4 4.6
  9. I'm stumped on Engine Temperature
  10. please help.
  11. It just won't start.....
  12. code help
  13. 1993 4.9L Fails Emissions--Badly
  14. new to the 5.4L...
  15. A BIG "Thank You" to all......
  16. HELP !! Cold Stumble - Warm ok
  17. Very nice clutch
  18. Replacing Engine, Does the Eng. Year really matter?
  19. He with the most toys wins
  20. installed me K&N air intake tonight
  21. P0401
  22. HELP!! Broken exhaust manifold bolts
  23. 4.6 head milling or not on a head gasket swap?
  24. need help on fuel filter removal
  25. hooking up tach on a 1997 4.2
  26. Plugs have been in 9+ years!
  27. Help needed, hesitation in drivetrain
  28. Injector Isues
  29. 02 v6 cold stumble warm ok
  30. engine cooling problems
  31. coil pack nightmare
  32. 2000 navigator
  33. head milling
  34. high reaving at start
  35. Average cost of 5.8L Lightning Rebuild
  36. Engine Noise: Crickets/whiny sound is a loose plug
  37. v8 swap
  38. tranny darin and fill
  39. E85
  40. fuel pump info
  41. help replaced engine wont start
  42. Miss when started cold
  43. bent spark plug electrode
  44. 0174 code
  45. truck trying to stall on idle
  46. Changed Plugs, Clicking no start
  47. Calling all experts.... starter issues
  48. Roaring noise on start
  49. Correct Air Filter?
  50. F 150 power
  51. spark knock
  52. What kind of gas mileage is everyone getting
  53. Tune up
  54. Engine light came on & no Cruise Control
  55. need size of torqs socket to remove the drive shaft.
  56. Cooling issues on 2000 F-150 5.4
  57. starter connections
  58. Oil Filters
  59. HOw many o2 Heat Sensors in 1996 f_150?
  60. HOw many o2 Heat Sensors in 1996 f_150?
  61. Ignition problem
  62. Weird Engine Reving, Tach Bouncing
  63. Power Loss and shakeing???????
  64. Battery cable - Stupid question
  65. 1997 F-150 Harmonis Balancer Replacement
  66. NGK Iridium spark plugs
  67. F150 - Fuel Pump Issue. Drop tank or Remove Bed?
  68. heater hose/coils???
  69. Engine Check light came on.....
  70. Just blew a plug July 13, 2006
  71. Any one lookin for an engine???
  72. 2000 5.4 need help?
  73. big puddles equal problems!
  74. non PI to PI intake manifold adapters
  75. stumped 2000 ford 150
  76. None of my 3 Fuel pumps turn on.
  77. Alternative Fuel Question
  78. A/C question
  79. Timing chain rattle when hot -- NOT at startup
  80. Problem with gear selector spring
  81. Rough Accel... but... weird
  82. help!! need vacuum diagram for 97 f150 4.2L
  83. air filter
  84. Engine possibly blown
  85. doing a head gasket job on a 4.6L need advice please
  86. Question about 2004 Ford 5.4L Triton 3 Valve engine
  87. Help whats the value for X08 in a 1999 f-150?
  88. OBD Code Help
  89. Rough starts...
  90. fuel air mixture metering problem
  91. '97 4.6 romeo - is it really that bad?
  92. wondering????
  93. Alternator
  94. throttle body spacer
  95. P0353????
  96. Rear main seal
  97. Does anybody know lawnmowers?
  98. Hybrid F150.
  99. Engine Ticking
  100. Emissions on 81 model
  101. Please Help!!!!!!!!
  102. noise
  103. No compression in cylinder #3, after blown plug
  104. Starting Issues
  105. Is this a fuel issue?
  106. cool clip...
  107. Fuel economy down under,how dose yours compare?
  108. parts help
  109. Why is my gas mileage so bad?
  110. Engine knocking
  111. popping noises after installing cold air intake ?
  112. Rough Idle 5.4l
  113. '92 & '95 5.0 Engine
  114. Need some help
  115. Performance issues
  116. throttle body spacers
  117. Troyer head work
  118. 98 f150 starter?
  119. camshaft position sensor
  120. 4.6 threw the p0304 code!
  121. SES light, HELP appreciated
  122. max perf 5.4:L
  123. Surging
  124. Looking to get more performance
  125. Need Help Please-Loss of Power/Response
  126. ac compressor
  127. spark plugs
  128. cats or no?
  129. 94 5.4 looses power when hot
  130. 250k and second set
  131. spark plug/service questions
  132. spark plug/service questions
  133. engine noise
  134. 460 in a '73 Mach 1?
  135. 99 f150 cam sensor signal/fuel system
  136. Buying a 4.6 or 5.6 w/ over 70k? What to look for or do?
  137. Engine Size?
  138. Error Code B1352 Ignition Key-in Circuit Failure
  139. Intake for '06 4.6L
  140. How to get the most HP and torque?
  141. Replacing o2 Sensors
  142. Understanding the EFI jargon
  143. blown plug helping out.
  144. Question about Codes??? Engine Hesitating Bad!!
  145. real coolant temp gauge
  146. fan clutch stuck????
  147. My dealership admits to the plug blow out problem!!
  148. 2001 - 105 K Kms Plug Replacement
  149. Fuel relay switch location
  150. fuel pump relay switch location 1990 f-150
  151. Need coilpack test values
  152. Engine thermostat temp
  153. fluid temperatures
  154. 2004 4.6L F-150, Intake?
  155. A/C pully needs to be changed, 98 4.6
  156. '02 F150 4.6L Missing and CEL is on What could it be?
  157. Summer air temps effect on MPG
  158. Engine miss or shake while towing
  159. K&N intake vs Fram Boost inkate
  160. Help! Ignition Cylinder no key!!! and Po401
  161. wont start
  162. Aftermarket bolt-ons
  163. Mustang engine interchangeable with F150
  164. fuel filter
  165. questions about egr on '92 302
  166. Mustang parts installation?
  167. Pinging on 4.6L under load
  168. 351 heads....EFI heads and carb motor
  169. P1506 Finally Solved
  170. Now What????
  171. doing a head gasket job on a 4.6, need tips and advice
  172. rod knock
  173. 351w upgrades
  174. Pulley Question On 04 F150 Fx4 3v 5.4l
  175. Dead on Highway
  176. E Fan
  177. 4.6 blowers ???
  178. f150 wont start...
  179. Engine swap
  180. '99 F-250 5.4L cylinder not firing
  181. Oil change - what else to lube???
  182. 3000 rpm stall???
  183. Motor oil, preference...
  184. engine change
  185. F-150 won't start-fuel?
  186. 02 f150 engine noise
  187. Calling the EGR gurus
  188. Engine noise on 6cyl.--sounds like a diesel?
  189. Vibration 91 F150
  190. engine trouble
  191. 5.4L low vacuum
  192. A Tick that Goes Away at the Exact Same Time?
  193. oil filter spitting oil after oil change - GOOD STORY
  194. First time oil change
  195. 1997 f150 v6 2wd
  196. Help need better gas mileage
  197. problems with 05 5.4L
  198. looking for a link to decode my 1986 door data plate
  199. Wheel Bearing Replacement Question
  200. Spark plug coils
  201. CPR fuel injection system cleaner
  202. my wife dislikes my bent rod
  203. Seafoam
  204. Marbles in my motor
  205. 202,365 miles here and FINALLY -
  206. poweraid throttle body spacer ...HELP...!!!
  207. Can I beat the dead horse some more? v6 swap
  208. Alex Pepper's OBD-2.com software and interface
  209. EGR problem? Code P0405
  210. Blown PLUG JB WELD update
  211. How to check Motor Codes?
  212. 2001 Mazda Tribute keeps going!! HELP!
  213. Fan belt?
  214. Cheap Mods to add HP?
  215. Water temp sensor
  216. 4.6 & 5.4 heads ?
  217. Working On Your Own Truck
  218. Eating plugs???
  219. IAC question
  220. Look here if you've used Timeserts
  221. 1994 F150 4.9L 300 Temperature Gauge
  222. Bill Mitchell in 99" F150
  223. Engine code P0174 and P1131
  224. Changed 4.6 engine need help on sensors
  225. Impending spark plug blowout- what to do?
  226. Cilinder 7 misfire
  227. Suggestions for uses of my big lawn ornament
  228. Sove your MISFIRE problems!
  229. Front fuel tank leak/overflow '92 2wd std cab long box
  230. Dtc #1151
  231. My truck has balls now!
  232. #5 Spark Plug blow out, 50k
  233. Idling
  234. 3rd altenator this year
  235. Ive got major problems
  236. Puzzling question after I switched to Synthetic?
  237. Engine quits while driving
  238. what can i expect to pay for a 4.6 motor and install?
  239. fuel injector problems.....
  240. 150 Ranger question
  241. Truck Wont Idle
  242. truck smokes when cranked
  243. Removing the Factory Oil Filter for the First Oil Change
  244. aftermarket radiators
  245. ford big blocks
  246. How many gallons left when fuel light comes on
  247. Performance question
  248. HELP..... I Need More HP!!
  249. Think you have all the f-150 answers? Take a stab at this one.
  250. 2008 f-150's
