P0171 & P0174 OBD codes
Old Mar 4, 2009 | 10:52 PM
Tat2ski's Avatar
I had 2 OBD II codes come up with P0171 & P0174 that state system too lean (Bank 1 & 2). What is the most likely culprit for getting a code like this? I read on a search that MAF sensor could be dirty or not working? I have a 98 F150 with 112k with a 4.6L.
Has anyone had these 2 codes come up?
I would like to troubleshoot the most common reasons, and go from there.
Old Mar 4, 2009 | 11:02 PM
shifty_85's Avatar
MAF dirty. a vac. leak somewere past the MAF. bad or wrong spark plugs and bad o2's i think i coverd most of the things that could make it run lean....but not all of them...
Old Mar 5, 2009 | 11:06 AM
Tat2ski's Avatar
Codes
I think its probably a dirty MAF sensor due to the hesitation at take off. It has been running poorly just as I accelerate from a stop, and previously thought that problem was my clutch which had just been rebuilt.
Thanks for the info.
Old Mar 5, 2009 | 11:17 AM
The most common cause is actually a vacuum leak, specifically the PCV elbow behind the engine. LOTS of threads on this here.
Old Mar 5, 2009 | 11:49 AM
tjk_in_cny's Avatar
X2.......If you use the search function on this site, you will probably find every answer you are looking for concerning these two codes. I have a detailed thread on this subject from a year ago. This is one of the most talked about CODE issues on this site.
Go to search (top black bar, 3rd from the right). type in P0171 and/or P0174 and put aside a few hours, because there is alot to read.
Good Luck with it.
TJK
