98 f 150 tune up
Old Feb 25, 2009 | 03:38 PM
hvykvy's Avatar
98 f 150 tune up
hey i got a 98 f150 with the 4.6l i am doing to be changing the coils, wires and plugs this wekend. i just have a question what kind of spark plugs do you guys recomend? i was thinking motorcraft plugs. any help would be good
Old Feb 25, 2009 | 04:14 PM
tjk_in_cny's Avatar
MotorCraft is your best choice. Use at least a single platinum plug.
I'm pretty sure that if you are changing the coils as well, that you are supposed to disconnect the battery. I do when ever I am working on the ignition system. You will be changing alot of parts, this will also reset your PCM to factory parameter's and allow you to go through some drive cycles so that the PCM can re-learn the drive cyles with the new parts you put in.
Good luck with the change.
TJK
Old Feb 25, 2009 | 04:29 PM
Matts ford's Avatar
yea motorcraft, denso, or ngk plugs. motorcraft is the best though. make sure you use motorcraft wires too. some people get lucky with aftermarket wires on the modular engines but alot of people dont. same thing goes for the plugs. and make sure you use dielectric grease inside the wire boots and you'll be good to go.
Old Feb 25, 2009 | 05:51 PM
98Expedition10's Avatar
I had to recently tune up my 98 Expedition for maintenance duty. Here is what I used; nothing out of the norm for these engines.
Plugs:
Motorcraft AWSF-32PP Specification Plugs:
Motorcraft, SP432, Single Contact Plugs, wi .054" Gap.
Plug Wire Set (Replacement Highly Recommended)
Duralast, Model 4643 Cable Set.
Old Feb 25, 2009 | 06:04 PM
Camarothatcould's Avatar
Why coils?
Old Feb 26, 2009 | 12:19 AM
hvykvy's Avatar
won of the arginal coil packs went bad so i replaced the coils with napa coils at 120,000 miles. and i changed the plugs at 85,000 miles but kept the orginal wires on it. now i have 125,000 on it and its starting to run rough so im going to change the wires and plugs and go from there
Old Feb 26, 2009 | 11:42 AM
I went 171k on my 4.6 coil packs. I now am reusin them on the 5.4
Old Feb 26, 2009 | 12:46 PM
hvykvy's Avatar
ya mine went bad things happen
