IAC Brand
Old Feb 18, 2009 | 11:48 PM
hillbilly4u's Avatar
IAC Brand
No one seems to mention which IAC brand seems to be better. Local parts here only stock BWD's. Anyone had bad luck with these?
Old Feb 19, 2009 | 02:10 PM
Matts ford's Avatar
i never heard anyone say anything bad about any brand iac. a couple of people on here have autozones on theres and they havent had any problems with them. they were like 47 bucks i think.
Old Feb 19, 2009 | 05:01 PM
Thought I read where some didn't last to long. Anyway thats about the price of this one. Thanks for the reply.
Old Feb 19, 2009 | 05:49 PM
jbrew's Avatar
Your thinking of the DPFE sensors. I purchased an IAC from Rock a couple years ago and had no problems. As far as I know - Nobody sells bad ones.
Old Feb 20, 2009 | 11:51 PM
Cleaning the IAC didn't fix the idle up problem I'm having when going into gear, so I put a new one on tonight. Helped a little bit. Now it is staying at higher idle for longer at cold start up like it should. Borrowed a friends vac tool and did the suck test on the egr. Its working too. Anyone have any more ideas to try?
Old Feb 22, 2009 | 10:25 AM
Ideas??
Old Feb 22, 2009 | 11:04 AM
jethat's Avatar
you did restart the pcm by disconnecting the battery for several minutes?
Old Feb 23, 2009 | 12:34 AM
Yep did the PCM relearn. Its some better. Idles and runs great. Park to reverse or drive, and before it goes into gear it will idle up 300 rpm's causing a pretty rough clunk.
