What is the "semi" in Motorcraft semi synthetic oil?
You'll find that the Motorcraft semi is a blend oil. In the case of Motorcraft oil, unless something has changed recently, it was being bottled by Conoco-Phillips. It had the same formulation as the Phillips Trop Artic and Kendall oils. Both of these use far more GP III synthetic basestock than most other blends with the percentage closer to 60% per tech at CP. FWIW, the blends are the best of all of the oil technologies and turn in the lowest wear metals versus full synthetics. There is no standard as to how much synthetic has to be in the mix to be a blend. Apparently, a splash will do.
I use the regular Mobil-1 5w-20, with a Motorcraft FL-820's filter at 3K intervals religiously! Yeah it may be overkill, but my friend has done the same
with his old Ford Ranger/ same regular Mobil-1 3K change intervals & is currently at 400K miles, & engine runs fine!............Really can't argue with those results!............
