Foam on oil cap
Old Feb 16, 2009 | 08:22 PM
Agent Chaos's Avatar
Foam on oil cap
Hi all-
I have a 2001 F-150 with 5.4 V8. I've noticed over the past couple of years, that during the cold winter month's when I change oil, there is a build up of foam on the underside of the oil cap. I don't notice it in the summer, but just yesterday I noticed it. I'm not using any coolant; the fluid level stays constant. Just curious if this is normal or not. Thanks in advance.
-A. Chaos
Old Feb 16, 2009 | 08:24 PM
Matts ford's Avatar
its completely normal. its just a little bit of moisture. its mainly from taking short drives. there are a mess of threads with the same concern.
Old Feb 16, 2009 | 08:36 PM
RUSS04's Avatar
I have the same on my 2004 I just pull the oil cap off once a week and wipe it clean I also wad up a piece of paper towel and stick it down the tube on the valve cover to suck up the moisture thats in there
Old Feb 16, 2009 | 08:38 PM
Thanks!
Thanks, fellas, really do appreciate the info!
Old Feb 16, 2009 | 08:41 PM
Matts ford's Avatar
no offense but... why?
IMO that would be a waste of time because its not like i can stop the moisture from getting in my engine.
Old Feb 16, 2009 | 09:09 PM
RUSS04's Avatar
You would be suprised how much gunk is on that paper towel when you pull it out I know i cannot stop the moisture but i try to keep it clean
Old Feb 16, 2009 | 09:40 PM
jbrew's Avatar
I do the same thing I hate that it does that in the winter. I don't know if it helps anything or not, it still runs thru the PCV system, but you can get a in line separator to keep from going any further.
Old Feb 16, 2009 | 09:46 PM
RUSS04's Avatar
Thanks jbrew
